Ir para o conteúdo principal
Asus 1015E-DS03 Screen Replacement
O que você precisa
  1. Asus 1015E-DS03 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Hold the laptop using both hands with the battery facing upwards.
    Pergunte ao FixBot
    Comentar
  2. Asus 1015E-DS03 Screen Replacement: passo 2, imagem 1 %32
    • Push the two tabs located below the battery in towards each other using your thumbs.
    Pergunte ao FixBot
    Comentar
  3. Asus 1015E-DS03 Screen Replacement: passo 3, imagem 1 %32
    • Push the battery upwards and out of the laptop as shown.
    Pergunte ao FixBot
    Comentar
  4. Asus 1015E-DS03 Screen Replacement: passo 4, imagem 1 %32
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
    Pergunte ao FixBot
    Comentar
  5. Asus 1015E-DS03 Screen Replacement, Front Screen Case: passo 5, imagem 1 %32
    • Push up on the back of the tabs that cover the hinges connecting the screen to the base of the laptop.
    • While pushing up on the back of the tabs, insert the spudger into the opening created from pushing on the tabs until the tab detaches.
    Pergunte ao FixBot
    Comentar
  6. Asus 1015E-DS03 Screen Replacement: passo 6, imagem 1 %32 Asus 1015E-DS03 Screen Replacement: passo 6, imagem 2 %32
    • Once the case has been separated from the laptop, pull the case off completely, using the plastic opening tool or your fingers.
    • You will hear popping noises which are to be expected.
    Pergunte ao FixBot
    Comentar
  7. Asus 1015E-DS03 Screen Replacement: passo 7, imagem 1 %32
    • When the screen case has been successfully removed, the laptop should resemble the photo shown here.
    Pergunte ao FixBot
    Comentar
  8. Asus 1015E-DS03 Screen Replacement, Screen: passo 8, imagem 1 %32
    • Unscrew the 3 mm screws (4) using a #0 Phillips head screwdriver.
    Pergunte ao FixBot
    Comentar
  9. Asus 1015E-DS03 Screen Replacement: passo 9, imagem 1 %32 Asus 1015E-DS03 Screen Replacement: passo 9, imagem 2 %32
    • Lift the screen away from the computer.
    • Be careful removing the screen, as the left side is still connected to the computer.
    Pergunte ao FixBot
    Comentar
  10. Asus 1015E-DS03 Screen Replacement: passo 10, imagem 1 %32 Asus 1015E-DS03 Screen Replacement: passo 10, imagem 2 %32
    • Remove the wire that is glued to the back of the screen with your fingers.
    • Remove the tape covering the connection port.
    Pergunte ao FixBot
    Comentar
  11. Asus 1015E-DS03 Screen Replacement: passo 11, imagem 1 %32
    • Separate the screen from the computer by gently pulling it out.
    Pergunte ao FixBot
    Comentar
  12. Asus 1015E-DS03 Screen Replacement: passo 12, imagem 1 %32
    • Upon removal, the computer should look like this picture.
    Pergunte ao FixBot
    Comentar
Conclusão
Becca Day
Membro desde: 03/23/16
321 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 7-4, Benson Spring 2016 Membro de Clemson, Team 7-4, Benson Spring 2016
CLEM-BENSON-S16S7G4
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 41
Ao todo: 1,102
