Ir para o conteúdo principal
Astro Pyle PTBL7C Battery Replacement
O que você precisa
  1. Astro Pyle PTBL7C  Battery Replacement, Battery: passo 1, imagem 1 %32
    • Use the spudger to open the device from the front edge of the screen. Gently slide it in and push it up to open.
    • It may emit a cracking sound at it opens; this is only the locks coming apart.
  2. Astro Pyle PTBL7C  Battery Replacement: passo 2, imagem 1 %32 Astro Pyle PTBL7C  Battery Replacement: passo 2, imagem 2 %32
    • The battery will appear as pictured. Separate the back case from the device. Avoid damaging the wire that connects the speakers between the two halves of the case.
  3. Astro Pyle PTBL7C  Battery Replacement: passo 3, imagem 1 %32
    • The battery is attached in two different ways; one wire is attached to the screen to support the screen's background led lights. Carefully desolder the wire without damaging the part connecting the battery to the screen.
  4. Astro Pyle PTBL7C  Battery Replacement: passo 4, imagem 1 %32
    • Desolder the wires pictured. These feed energy from the battery into the motherboard.
    • Use caution to avoid damaging the motherboard or other critical pieces.
  5. Ferramenta utilizada neste passo:
    Plastic Cards
    $2.99
    • Use a plastic card to gently break the adhesive holding the battery to the metal screen plate. Remove the battery.
    • Though non-functional, the battery still contains dangerous chemicals. Handle it directly as little as possible.
    • Install the new battery and solder all the connections back in place.
    • Visit this guide for more information on soldering and desoldering: iFixit Soldering Guide
Conclusão
Abdulelah
Membro desde: 10/22/16
214 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 5-5, Wilson Fall 2016 Membro de IUPUI, Team 5-5, Wilson Fall 2016
IUPUI-WILSON-F16S5G5
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 398
