Ir para o conteúdo principal
Astro Mixamp Control Button Replacement
O que você precisa
  1. Astro Mixamp Control Button Replacement, Panel Dial: passo 1, imagem 1 %32 Astro Mixamp Control Button Replacement, Panel Dial: passo 1, imagem 2 %32
    • Grip the dial tightly and pull straight off the device.
    • Repeat for the second dial
    Pergunte ao FixBot
  2. Astro Mixamp Control Button Replacement: passo 2, imagem 1 %32 Astro Mixamp Control Button Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, remove the spacer nuts and washers from each dial post.
    Pergunte ao FixBot
  3. Astro Mixamp Control Button Replacement, Outer Casing: passo 3, imagem 1 %32 Astro Mixamp Control Button Replacement, Outer Casing: passo 3, imagem 2 %32
    • Before opening your device, ensure the device is not on or connected to the charging cable.
    • Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
    • Pull the rubber foot free of the plastic casing.
    Pergunte ao FixBot
  4. Astro Mixamp Control Button Replacement: passo 4, imagem 1 %32
    • Use a screwdriver to remove the screw from the rear casing.
    Pergunte ao FixBot
  5. Astro Mixamp Control Button Replacement: passo 5, imagem 1 %32
    • Gently lift the rear casing from the device.
    Pergunte ao FixBot
  6. Astro Mixamp Control Button Replacement, Motherboard: passo 6, imagem 1 %32 Astro Mixamp Control Button Replacement, Motherboard: passo 6, imagem 2 %32 Astro Mixamp Control Button Replacement, Motherboard: passo 6, imagem 3 %32
    • Remove the four screws that hold the motherboard in place.
    • Only touch the edges of the motherboard. Touching the surface can damage the motherboard.
    Pergunte ao FixBot
  7. Astro Mixamp Control Button Replacement: passo 7, imagem 1 %32
    • Gently pull the motherboard from the front cover.
    Pergunte ao FixBot
  8. Astro Mixamp Control Button Replacement, Control Button: passo 8, imagem 1 %32 Astro Mixamp Control Button Replacement, Control Button: passo 8, imagem 2 %32
    • Gently insert a metal spudger under a control button housing.
    • Do not pry the button housing from the front panel, this can cause damage to the button.
    • Rotate the control button around the marked pin.
    Pergunte ao FixBot
Conclusão
Hope Burns
Membro desde: 10/29/16
741 Reputação
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 47
Ao todo: 1,997
