Introdução
The battery is what gives the headset the power to run and function. This guide will show you how to remove the battery from the headset.
O que você precisa
Remove the magnetic ear pads by gently pulling up away from the head set.
Remove the five 6mm PH1 screws.
Remove the buttons panel by pulling the panel away from the white ribbon cord.
14 outras pessoas executaram este guia.
10 comentários
Is this for the Gen III Astro a50?
Yes it’s for the Gen 3 A50
Where do I buy a battery though….
