Ir para o conteúdo principal
Astro A40 Gen2 Mixamp Button Replacement
O que você precisa
  1. Astro A40 Gen2 Mixamp Button Replacement, Remove Dials: passo 1, imagem 1 %32 Astro A40 Gen2 Mixamp Button Replacement, Remove Dials: passo 1, imagem 2 %32 Astro A40 Gen2 Mixamp Button Replacement, Remove Dials: passo 1, imagem 3 %32
    • Remove the dials using either a metal spudger or your hands. Be careful as the dials may be difficult to remove.
    Pergunte ao FixBot
    Comentar
  2. Astro A40 Gen2 Mixamp Button Replacement, Remove nuts and washers.: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Locate the two 11/32 inch nuts underneath the dials.
    • Use an 11/32 inch socket wrench or tweezers to unscrew and remove the nuts and washers.
    Pergunte ao FixBot
    Comentar
  3. Astro A40 Gen2 Mixamp Button Replacement, Remove back pad.: passo 3, imagem 1 %32 Astro A40 Gen2 Mixamp Button Replacement, Remove back pad.: passo 3, imagem 2 %32
    • Using a larger metal spudger, remove the rubber back of the mixamp.
    • The back will have glue residue after removal. Depending on the stickiness of the residue, more glue may be needed to stick the backing back on.
    Pergunte ao FixBot
    Comentar
  4. Astro A40 Gen2 Mixamp Button Replacement, Take out main case screw.: passo 4, imagem 1 %32
    • Remove the one 4.5 mm Phillips #0 screw on the back panel of the mixamp.
    Pergunte ao FixBot
    Comentar
  5. Astro A40 Gen2 Mixamp Button Replacement, Pry open the case.: passo 5, imagem 1 %32 Astro A40 Gen2 Mixamp Button Replacement, Pry open the case.: passo 5, imagem 2 %32 Astro A40 Gen2 Mixamp Button Replacement, Pry open the case.: passo 5, imagem 3 %32
    • Using a large metal spudger, detach all plastic clips holding the bottom and top casings together.
    • Remove the input casing using your fingers.
    • Be careful when releasing the clips between the two casings, as it is very easy to scratch the mixamp or break the clips.
    • Use caution when pulling the two casings apart as it is very easy to pinch your fingers between them.
    Pergunte ao FixBot
    Comentar
  6. Astro A40 Gen2 Mixamp Button Replacement, Remove the motherboard from the case.: passo 6, imagem 1 %32
    • Remove the four 5.8 mm Phillips #0 screws on the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Astro A40 Gen2 Mixamp Button Replacement: passo 7, imagem 1 %32 Astro A40 Gen2 Mixamp Button Replacement: passo 7, imagem 2 %32
    • Remove the motherboard from the casing.
    Pergunte ao FixBot
    Comentar
  8. Astro A40 Gen2 Mixamp Button Replacement, Mixamp Button: passo 8, imagem 1 %32 Astro A40 Gen2 Mixamp Button Replacement, Mixamp Button: passo 8, imagem 2 %32
    • Use a metal spudger to pry off the buttons and remove them.
    • You may need to apply pressure to break off the small black caps which hold the buttons down. The buttons will still function without the black caps.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Mark
Membro desde: 01/22/15
412 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 20-18, Maness Winter 2015 Membro de Cal Poly, Team 20-18, Maness Winter 2015
CPSU-MANESS-W15S20G18
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 26
Ao todo: 2,645
