Ir para o conteúdo principal
Astro A20 Battery Replacement
O que você precisa
  1. Astro A20 Battery Replacement, Cushion: passo 1, imagem 1 %32
    • Place one hand on the hard side of the headset ear portion and on the cushion.
    • Lift the small portion on the edge of the cushion.
    Pergunte ao FixBot
    Comentar
  2. Astro A20 Battery Replacement: passo 2, imagem 1 %32
    • Slide the metal spudger underneath the lift part of the ear cushion.
    • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
    Pergunte ao FixBot
    Comentar
  3. Astro A20 Battery Replacement: passo 3, imagem 1 %32 Astro A20 Battery Replacement: passo 3, imagem 2 %32
    • Remove the ear cushion from the headset.
    Pergunte ao FixBot
    Comentar
  4. Astro A20 Battery Replacement, Battery: passo 4, imagem 1 %32
    • Place hand on the opposite side of the speaker.
    Pergunte ao FixBot
    Comentar
  5. Astro A20 Battery Replacement: passo 5, imagem 1 %32 Astro A20 Battery Replacement: passo 5, imagem 2 %32
    • Remove the four 7mm screws with a Phillips #1 screwdriver.
    • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
    Pergunte ao FixBot
    Comentar
  6. Astro A20 Battery Replacement: passo 6, imagem 1 %32
    • Lift and remove the speaker from the headset.
    Pergunte ao FixBot
    Comentar
  7. Astro A20 Battery Replacement: passo 7, imagem 1 %32
    • Remove the two 7mm screws with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  8. Astro A20 Battery Replacement: passo 8, imagem 1 %32
    • Lift the motherboard to expose the battery.
    Pergunte ao FixBot
    Comentar
  9. Astro A20 Battery Replacement: passo 9, imagem 1 %32
    • Remove the battery with a plastic spudger.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
3Comentários do guia
Does it work for Astro A20 2nd Gen too?
Charly - Responder Compartilhar
this guide is so wrong! 1st the battery is on the left side by the charging port (a20 2gen)
Miguel Garcia - Responder Compartilhar
That head set is A20 gen1 but main board in right side
from 7th pic that is right side
If you have no idea which is left side or right side.
just check where is buttons
Leo Lee - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 32
Últimos 30 dias: 179
Ao todo: 20,606
