Ir para o conteúdo principal
Astro A20 Microphone Replacement
O que você precisa
  1. Astro A20  Microphone Replacement, Cushion: passo 1, imagem 1 %32
    • Place one hand on the hard side of the headset ear portion and on the cushion.
    • Lift the small portion on the edge of the cushion.
    Pergunte ao FixBot
    Comentar
  2. Astro A20  Microphone Replacement: passo 2, imagem 1 %32
    • Slide the metal spudger underneath the lift part of the ear cushion.
    • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
    Pergunte ao FixBot
    Comentar
  3. Astro A20  Microphone Replacement: passo 3, imagem 1 %32 Astro A20  Microphone Replacement: passo 3, imagem 2 %32
    • Remove the ear cushion from the headset.
    Pergunte ao FixBot
    Comentar
  4. Astro A20  Microphone Replacement, Microphone: passo 4, imagem 1 %32
    • Place one hand on the back of the speaker.
    Pergunte ao FixBot
    Comentar
  5. Astro A20  Microphone Replacement: passo 5, imagem 1 %32 Astro A20  Microphone Replacement: passo 5, imagem 2 %32
    • Remove the four 7mm screws with a Phillips #1 screwdriver.
    • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
    Pergunte ao FixBot
    Comentar
  6. Astro A20  Microphone Replacement: passo 6, imagem 1 %32 Astro A20  Microphone Replacement: passo 6, imagem 2 %32
    • Lift the speaker area.
    • Disconnect the wires that connect the microphone.
    • Remove the 7mm screw with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
Conclusão
9 outras pessoas executaram este guia.
5Comentários do guia
worked for me….thanks
Thompson Crusher - Responder Compartilhar
listen my mic peace is messed up is there like a fix for that
Bruh Bruh - Responder Compartilhar
were? are you getting the new mic from? please link the site
jrod6t9 - Responder Compartilhar
this really worked! There was no need to get a replacement mic since it was just a torn cable not making good contact. Thanks a lot!
Lineth Jauregui - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 30
Últimos 30 dias: 114
Ao todo: 15,646
