Ir para o conteúdo principal
Astak Mole Motherboard Replacement
O que você precisa
    1. Astak Mole Motherboard Replacement, Lower Case: passo 1, imagem 1 %32
      • Remove the four bottom tabs in order to access the bottom screws.
      Pergunte ao FixBot
      Comentar
    2. Astak Mole Motherboard Replacement: passo 2, imagem 1 %32
      • Remove all four 14 mm Phillips #1 screws.
      Pergunte ao FixBot
      Comentar
    3. Astak Mole Motherboard Replacement: passo 3, imagem 1 %32
      • Remove the SD card.
      Pergunte ao FixBot
      Comentar
    4. Astak Mole Motherboard Replacement: passo 4, imagem 1 %32
      • Pry up the motherboard on the four points using a spudger.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
      Pergunte ao FixBot
      Comentar
    5. Astak Mole Motherboard Replacement: passo 5, imagem 1 %32
      • Gently pull back the motherboard to expose many of the component's wired connections.
      Pergunte ao FixBot
      Comentar
    1. Astak Mole Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 Astak Mole Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
      • Sever the indicated adhesive connections to the motherboard allowing the wired connections to be removed.
      • All wired connections to the motherboard are removed by the thin plastic male connector inserted into the larger female plastic connection.
      Pergunte ao FixBot
      Comentar
    2. Astak Mole Motherboard Replacement: passo 7, imagem 1 %32 Astak Mole Motherboard Replacement: passo 7, imagem 2 %32
      • The red wires may be adhered to the CPU as indicated and will need to be severed as shown.
      • Be careful not to scratch the CPU in this step. This is not a wired connection.
      • Sever the additional adhesive connections so that the wired connections may be removed.
      Pergunte ao FixBot
      Comentar
    3. Astak Mole Motherboard Replacement: passo 8, imagem 1 %32
      • Locate and unscrew the indicated screw using the (PH1) Phillips head bit.
      • Screw Measurements: (Length= 5.3mm)
      Pergunte ao FixBot
      Comentar
    4. Astak Mole Motherboard Replacement: passo 9, imagem 1 %32 Astak Mole Motherboard Replacement: passo 9, imagem 2 %32
      • Remove the last two wired connections to the motherboard by severing the indicated connections.
      • Lift up the secondary motherboard as indicated using the metal spudger.
      • All connections should be severed from the motherboard and a new motherboard may be inserted.
      • It is advised to reapply adhesive to wired connections during reassembly.
      Pergunte ao FixBot
      Comentar
Conclusão
Andrew Birch
Membro desde: 09/15/16
204 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 2-2, Blackwell Fall 2016 Membro de USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 31
Ao todo: 942
