Ir para o conteúdo principal
Astak Mole Camera Head Replacement
O que você precisa
    1. Astak Mole Camera Head Replacement, Lower Case: passo 1, imagem 1 %32
      • Remove the four bottom tabs in order to access the bottom screws.
      Pergunte ao FixBot
      Comentar
    2. Astak Mole Camera Head Replacement: passo 2, imagem 1 %32
      • Remove all four 14 mm Phillips #1 screws.
      Pergunte ao FixBot
      Comentar
    3. Astak Mole Camera Head Replacement: passo 3, imagem 1 %32
      • Remove the SD card.
      Pergunte ao FixBot
      Comentar
    4. Astak Mole Camera Head Replacement: passo 4, imagem 1 %32
      • Pry up the motherboard on the four points using a spudger.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
      Pergunte ao FixBot
      Comentar
    5. Astak Mole Camera Head Replacement: passo 5, imagem 1 %32
      • Gently pull back the motherboard to expose many of the component's wired connections.
      Pergunte ao FixBot
      Comentar
    1. Astak Mole Camera Head Replacement, Camera Head: passo 6, imagem 1 %32
      • Unscrew the three screws connecting the base to the camera head with the PH1 size Phillips head bit.
      • Screw measurements: Length=7.0mm.
      • The third screw can be exposed by rotating the camera head.
      • Do not force the camera head farther than it will allow you.
      Pergunte ao FixBot
      Comentar
    2. Astak Mole Camera Head Replacement: passo 7, imagem 1 %32
      • Unscrew indicated Phillips head screws using the PH1 Phillips head bit to free wires.
      • Screw measurements: Length=3.5mm
      Pergunte ao FixBot
      Comentar
    3. Astak Mole Camera Head Replacement: passo 8, imagem 1 %32 Astak Mole Camera Head Replacement: passo 8, imagem 2 %32 Astak Mole Camera Head Replacement: passo 8, imagem 3 %32
      • Separate the three indicated outputs from the motherboard with metal spudger.
      • There is electrical adhesive on the output. This can be easily separated with the metal spudger.
      Pergunte ao FixBot
      Comentar
    4. Astak Mole Camera Head Replacement: passo 9, imagem 1 %32
      • Separate the wire from CPU by cutting adhesive with metal spudger.
      • It is advised to reapply adhesive to wired connections during reassembly, and to re-attach wires to CPU to prevent disconnection and loose wires inside device.
      • Be careful not to damage the CPU in the process. This is not a wired connection.
      Pergunte ao FixBot
      Comentar
Conclusão
Bryan
Membro desde: 09/15/16
104 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 2-2, Blackwell Fall 2016 Membro de USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 28
Ao todo: 903
