Ir para o conteúdo principal
Astak Mole Motor Replacement
O que você precisa
    1. Astak Mole  Motor Replacement, Lower Case: passo 1, imagem 1 %32
      • Remove the four bottom tabs in order to access the bottom screws.
      Pergunte ao FixBot
      Comentar
    2. Astak Mole  Motor Replacement: passo 2, imagem 1 %32
      • Remove all four 14 mm Phillips #1 screws.
      Pergunte ao FixBot
      Comentar
    3. Astak Mole  Motor Replacement: passo 3, imagem 1 %32
      • Remove the SD card.
      Pergunte ao FixBot
      Comentar
    4. Astak Mole  Motor Replacement: passo 4, imagem 1 %32
      • Pry up the motherboard on the four points using a spudger.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
      Pergunte ao FixBot
      Comentar
    5. Astak Mole  Motor Replacement: passo 5, imagem 1 %32
      • Gently pull back the motherboard to expose many of the component's wired connections.
      Pergunte ao FixBot
      Comentar
    1. Astak Mole  Motor Replacement, Electric Motor Assembly: passo 6, imagem 1 %32
      • Unscrew both screws using the Phillips head (PH1) screw bit and set aside for reassembly
      • Screw Measurements: Length: 7.1mm
      • The motor should be free of its housing and only be attached to the motherboard by its wires.
      Pergunte ao FixBot
      Comentar
    2. Astak Mole  Motor Replacement: passo 7, imagem 1 %32
      • Sever motor connection to motherboard and remove wire carefully.
      • Optional: Use electrical adhesive to prevent dislodging of new wired connection.
      Pergunte ao FixBot
      Comentar
Conclusão
Andrew Birch
Membro desde: 09/15/16
204 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 2-2, Blackwell Fall 2016 Membro de USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 22
Ao todo: 747
