Ir para o conteúdo principal
Assemble bObi Pet Post-Repair
O que você precisa
    1. Assemble bObi Pet Post-Repair, Connect the Cover: passo 1, imagem 1 %32 Assemble bObi Pet Post-Repair, Connect the Cover: passo 1, imagem 2 %32
      • Attach the 2 circuit plugs from bObi Pet's cover back onto her main board.
      • The yellow-wired plug connects to the right side of the mainboard.
      • The white-wired plug on bObi Pet’s lid connects to the middle of the mainboard.
      Pergunte ao FixBot
      Comentar
    2. Assemble bObi Pet Post-Repair, Align bObi Pet's Cover: passo 2, imagem 1 %32 Assemble bObi Pet Post-Repair, Align bObi Pet's Cover: passo 2, imagem 2 %32 Assemble bObi Pet Post-Repair, Align bObi Pet's Cover: passo 2, imagem 3 %32
      • Lay down bObi Pet's cover and line up the edges precisely.
      • While holding bObi Pet's top and bottom together, carefully flip her over onto a flat surface.
      Pergunte ao FixBot
      Comentar
    3. Assemble bObi Pet Post-Repair, Replace the Front Wheel: passo 3, imagem 1 %32 Assemble bObi Pet Post-Repair, Replace the Front Wheel: passo 3, imagem 2 %32 Assemble bObi Pet Post-Repair, Replace the Front Wheel: passo 3, imagem 3 %32
      • Reinstall the front wheel’s screw.
      • Then, place the front wheel on top and firmly push down to secure it.
      Pergunte ao FixBot
      Comentar
    4. Assemble bObi Pet Post-Repair, Secure the Cover: passo 4, imagem 1 %32 Assemble bObi Pet Post-Repair, Secure the Cover: passo 4, imagem 2 %32 Assemble bObi Pet Post-Repair, Secure the Cover: passo 4, imagem 3 %32
      • Replace the dustbin’s red fastener and install its 2 screws.
      • Install the 4 screws in the space beneath the brush compartment.
      Pergunte ao FixBot
      Comentar
    5. Assemble bObi Pet Post-Repair, Secure the Brushes on bObi Pet: passo 5, imagem 1 %32 Assemble bObi Pet Post-Repair, Secure the Brushes on bObi Pet: passo 5, imagem 2 %32 Assemble bObi Pet Post-Repair, Secure the Brushes on bObi Pet: passo 5, imagem 3 %32
      • Plug in the brush compartment.
      • Then, replace its red brush fastener and install the 2 screws.
      Pergunte ao FixBot
      Comentar
    6. Assemble bObi Pet Post-Repair, Replace the Bin Holders: passo 6, imagem 1 %32 Assemble bObi Pet Post-Repair, Replace the Bin Holders: passo 6, imagem 2 %32 Assemble bObi Pet Post-Repair, Replace the Bin Holders: passo 6, imagem 3 %32
      • Position the brush compartment back in its original place on bObi Pet.
      • Now reinsert the corner pieces on both sides of the dustbin, with the arms of the brush attachment linked.
      Pergunte ao FixBot
      Comentar
    7. Assemble bObi Pet Post-Repair, Replace the Dustbin: passo 7, imagem 1 %32 Assemble bObi Pet Post-Repair, Replace the Dustbin: passo 7, imagem 2 %32 Assemble bObi Pet Post-Repair, Replace the Dustbin: passo 7, imagem 3 %32
      • Ensure the rubber strip near bObi Pet's dustbin is not stuck underneath the brush compartment. Then, reinstall the 2 screws in each of the corner pieces.
      • Make sure the bin can slide in easily before using bObi Pet again and your repair is complete.
      Pergunte ao FixBot
      Comentar
Conclusão
After completing these steps, your bObi Pet should be back together in working order. Just replace any brushes and filters that may have been removed during disassembly.
Congratulations on completing your repair and happy cleaning!
Chelsea
Membro desde: 09/24/14
2.278 Reputação
Autoria de 31 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 364
