Ir para o conteúdo principal
ArmorAll AA255 Switch Replacement
O que você precisa
  1. ArmorAll AA255 Switch Replacement, Lower Motor Housing: passo 1, imagem 1 %32
    • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
    Pergunte ao FixBot
    Comentar
  2. ArmorAll AA255 Switch Replacement: passo 2, imagem 1 %32
    • Remove the five 15mm PH2 screws.
    Pergunte ao FixBot
    Comentar
  3. ArmorAll AA255 Switch Replacement: passo 3, imagem 1 %32
    • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
    Pergunte ao FixBot
    Comentar
  4. ArmorAll AA255 Switch Replacement: passo 4, imagem 1 %32 ArmorAll AA255 Switch Replacement: passo 4, imagem 2 %32
    • Gently separate the upper and lower sections of the main housing.
    Pergunte ao FixBot
    Comentar
  5. ArmorAll AA255 Switch Replacement, Switch: passo 5, imagem 1 %32
    • Using a PH2 screw head, unscrew the two 15mm screws as shown.
    Pergunte ao FixBot
    Comentar
  6. ArmorAll AA255 Switch Replacement: passo 6, imagem 1 %32 ArmorAll AA255 Switch Replacement: passo 6, imagem 2 %32 ArmorAll AA255 Switch Replacement: passo 6, imagem 3 %32
    • Pull the black handle.
    • Using a PH2 screwdriver, unscrew the single 12mm screw shown.
    Pergunte ao FixBot
    Comentar
  7. ArmorAll AA255 Switch Replacement: passo 7, imagem 1 %32 ArmorAll AA255 Switch Replacement: passo 7, imagem 2 %32
    • Use the blue opening tool to open up the black handle.
    Pergunte ao FixBot
    Comentar
  8. ArmorAll AA255 Switch Replacement: passo 8, imagem 1 %32 ArmorAll AA255 Switch Replacement: passo 8, imagem 2 %32
    • Using your fingers, gently take out the black cords.
    • Careful to not break the black cords.
    Pergunte ao FixBot
    Comentar
  9. ArmorAll AA255 Switch Replacement: passo 9, imagem 1 %32 ArmorAll AA255 Switch Replacement: passo 9, imagem 2 %32
    • Using the spudger, take out the switch. Do this by pushing the spudger against the switch on both sides as shown and then pull the switch out.
    Pergunte ao FixBot
    Comentar
  10. ArmorAll AA255 Switch Replacement: passo 10, imagem 1 %32
    • Replace the switch shown.
    Pergunte ao FixBot
    Comentar
Conclusão
Renzo La Rosa
Membro desde: 02/09/16
224 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-1, Baechle Spring 2016 Membro de IUPUI, Team 2-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G1
4 Membros
Autoria de 10 guias
1Comentário do guia
Any idea where to find a replacement switch? I did not see one on Amazon or eBay.
Mitchell Taylor - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 75
Ao todo: 3,506
