Ir para o conteúdo principal
Arlo Ultra 2 Speaker Replacement
O que você precisa
  1. Arlo Ultra 2 Speaker Replacement, Battery: passo 1, imagem 1 %32 Arlo Ultra 2 Speaker Replacement, Battery: passo 1, imagem 2 %32
    • Press the button on the bottom of the camera to release the case.
    • Pull the white case off of camera.
  2. Arlo Ultra 2 Speaker Replacement: passo 2, imagem 1 %32
    • Pull the white cube shaped battery from the back to remove it from camera.
  3. Arlo Ultra 2 Speaker Replacement, Speaker: passo 3, imagem 1 %32 Arlo Ultra 2 Speaker Replacement, Speaker: passo 3, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity. They are found in each corner.
  4. Arlo Ultra 2 Speaker Replacement: passo 4, imagem 1 %32 Arlo Ultra 2 Speaker Replacement: passo 4, imagem 2 %32
    • Using the spudger, loosen and remove the camera faceplate.
  5. Arlo Ultra 2 Speaker Replacement: passo 5, imagem 1 %32 Arlo Ultra 2 Speaker Replacement: passo 5, imagem 2 %32
    • Using the spudger, loosen and remove the back casing to expose the camera hardware.
  6. Arlo Ultra 2 Speaker Replacement: passo 6, imagem 1 %32 Arlo Ultra 2 Speaker Replacement: passo 6, imagem 2 %32
    • Very gently, pry the circuit boards apart from the white connector, removing the upper circuit board.
  7. Arlo Ultra 2 Speaker Replacement: passo 7, imagem 1 %32 Arlo Ultra 2 Speaker Replacement: passo 7, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove two 5.0 mm screws from the metal bracket.
    • Use a spudger to separate the long metal bracket.
    • There is an arrow etched into the bracket. It points towards the top of the camera. This is important when reassembling the camera.
  8. Arlo Ultra 2 Speaker Replacement: passo 8, imagem 1 %32 Arlo Ultra 2 Speaker Replacement: passo 8, imagem 2 %32 Arlo Ultra 2 Speaker Replacement: passo 8, imagem 3 %32
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each ZIF connector. Then, you can safely pull the cables out.
    • Be sure to pry up on the hinged flap, not the connector socket.
  9. Arlo Ultra 2 Speaker Replacement: passo 9, imagem 1 %32 Arlo Ultra 2 Speaker Replacement: passo 9, imagem 2 %32
    • Use a spudger to carefully push on each side of the speaker cable connector until it's out of its socket.
  10. Arlo Ultra 2 Speaker Replacement: passo 10, imagem 1 %32
    • Remove the small green circuit board.
  11. Arlo Ultra 2 Speaker Replacement: passo 11, imagem 1 %32 Arlo Ultra 2 Speaker Replacement: passo 11, imagem 2 %32 Arlo Ultra 2 Speaker Replacement: passo 11, imagem 3 %32
    • Feed the speaker cable through the opening to remove the speaker.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 146
