Introdução
This guide will help you repair a loose headphone jack on your Archos 5 tablet. Although this repair may take some time, don't be discouraged. You can do this yourself!
O que você precisa
Once you have opened your device, fold the screen away from the battery.
Unplug the touch pad from the motherboard. Do this by applying pressure on the thin black piece (attached at the bottom of the metallic foil.) Press the plastic spudger against the thin black piece and release it.
