Ir para o conteúdo principal
Apple iPod Dock Connector Cable Replacement
O que você precisa
  1. Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: passo 1, imagem 1 %32 Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: passo 1, imagem 2 %32 Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: passo 1, imagem 3 %32
    • Unscrew the four Phillips screws on the backside of the docking system.
    • The screws are located quite deep. Make sure you have a long screwdriver to be able to reach the screws.
    • Be aware of the plastic threads. Using too much force can tear this up.
  2. Apple iPod Dock Connector Cable Replacement: passo 2, imagem 1 %32
    • Separate the housing in two parts.
    • The dock connector is slid in two parts on the top of the system, make sure you slide the two housing parts in this line of direction.
    • The two parts are glued on the sides of the speakers. Use some force to separate the two housing parts.
    • The internal parts are still connected to each other. Don't pull the housing parts too far from each other.
  3. Apple iPod Dock Connector Cable Replacement: passo 3, imagem 1 %32
    • Slide the dock connector out of the housing part.
  4. Apple iPod Dock Connector Cable Replacement: passo 4, imagem 1 %32
    • Unscrew the three screws using a Phillips #2 screwdriver to remove the T-shaped circuit board holder.
  5. Apple iPod Dock Connector Cable Replacement: passo 5, imagem 1 %32
    • Remove the T-shaped circuit board holder.
  6. Apple iPod Dock Connector Cable Replacement: passo 6, imagem 1 %32
    • Remove the circuit board from the housing part.
    • The circuit board is still connected to another circuit board with a cable.
  7. Apple iPod Dock Connector Cable Replacement: passo 7, imagem 1 %32
    • Disconnect the 5-pin connector between the two circuit boards.
    • The connectors are tightly connected. Hold the other circuit board to prevent it from breaking while disconnecting the 5-pin connector.
  8. Apple iPod Dock Connector Cable Replacement: passo 8, imagem 1 %32 Apple iPod Dock Connector Cable Replacement: passo 8, imagem 2 %32
    • Look how the cables are oriented.
    • Take a picture with your phone. It's easier to look it up than recalling your memory.
  9. Apple iPod Dock Connector Cable Replacement: passo 9, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Desoldering Pump
    $3.99
    Comprar
  10. Apple iPod Dock Connector Cable Replacement: passo 10, imagem 1 %32
    • Heat up the solder.
    • If you don't want to damage your workspace, it's probably handy to place something underneath.
    • The circuit board will be getting hot. To make it more stable you can clamp it in a vise or alligator clips.
    • The heated solder tends to fume—do not inhale this! Do this in a well ventilated room.
  11. Apple iPod Dock Connector Cable Replacement: passo 11, imagem 1 %32 Apple iPod Dock Connector Cable Replacement: passo 11, imagem 2 %32
    • If the solder becomes fluid, keep the desoldering pump near the solder.
    • Push the button on the desoldering pump to suck the solder.
    • Solder will solidify fast, so you need to act quickly.
  12. Apple iPod Dock Connector Cable Replacement: passo 12, imagem 1 %32
    • Strip the cables with a wire stripper.
  13. Apple iPod Dock Connector Cable Replacement: passo 13, imagem 1 %32 Apple iPod Dock Connector Cable Replacement: passo 13, imagem 2 %32
    • Check if the cable is in the right position.
    • Heat up the contact point on the circuitboard.
    • If the contact point is hot enough, you can add a little bit of solder.
    • Don't inhale the fumes.
Conclusão
Om het apparaat weer te monteren, volg je deze instructies in omgekeerde volgorde vanaf stap 7.
Anoniem
Membro desde: 03/08/17
19 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 22
Duração total: 475
