Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Apple Watch Series 6 Screen Replacement
O que você precisa
  1. Apple Watch Series 6 Screen Replacement, Power down the watch: passo 1, imagem 1 %32 Apple Watch Series 6 Screen Replacement, Power down the watch: passo 1, imagem 2 %32
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Attach or remove the watch band as needed to provide more control as you make repairs.
  2. Apple Watch Series 6 Screen Replacement, Soften the display adhesive: passo 3, imagem 1 %32
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
    • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive softens.
  3. Apple Watch Series 6 Screen Replacement, Display opening: passo 4, imagem 1 %32 Apple Watch Series 6 Screen Replacement, Display opening: passo 4, imagem 2 %32 Apple Watch Series 6 Screen Replacement, Display opening: passo 4, imagem 3 %32
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, most distant to the digital crown.
    • Press firmly straight down into the gap.
    • Once inserted, tilt the blade to pry the display open slightly.
  4. Apple Watch Series 6 Screen Replacement: passo 5, imagem 1 %32 Apple Watch Series 6 Screen Replacement: passo 5, imagem 2 %32 Apple Watch Series 6 Screen Replacement: passo 5, imagem 3 %32
    • Insert an opening pick in the gap your created.
    • Slide the opening pick along the short edge of the watch to cut the adhesive.
  5. Apple Watch Series 6 Screen Replacement: passo 6, imagem 1 %32 Apple Watch Series 6 Screen Replacement: passo 6, imagem 2 %32
    • Slide the opening pick around the corner and along the long edge on the opposite side of the watch crown to cut the display adhesive.
  6. Apple Watch Series 6 Screen Replacement: passo 7, imagem 1 %32 Apple Watch Series 6 Screen Replacement: passo 7, imagem 2 %32
    • Slide the opening pick around the corner to cut the remaining adhesive on the short edge of the watch next to the watch crown.
  7. Apple Watch Series 6 Screen Replacement: passo 8, imagem 1 %32 Apple Watch Series 6 Screen Replacement: passo 8, imagem 2 %32
    • Place the watch on a flat surface and use an opening pick to slice through any remaining adhesive.
    • Try not to slice near the watch crown to prevent damaging the display cables. If you must slice near the crown, don't insert the opening pick deeper than 1/16th of an inch (~2 mm).
    • Slide an opening pick under the opposite display edge of the watch crown.
    • Twist the opening pick to loosen the display off the watch case.
    • Don't try to remove the display. It is still connected to the watch assembly.
  8. Apple Watch Series 6 Screen Replacement: passo 9, imagem 1 %32 Apple Watch Series 6 Screen Replacement: passo 9, imagem 2 %32 Apple Watch Series 6 Screen Replacement: passo 9, imagem 3 %32
    • Be careful not to strain the display cables when you fold the display to the side.
    • Lift the display and carefully pull it towards the watch crown.
    • Swing the display open to an upward position.
  9. Apple Watch Series 6 Screen Replacement, Soften the battery adhesive: passo 10, imagem 1 %32
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the rear side of the watch to loosen the battery adhesive. Leave the iOpener on the watch for at least two minutes.
  10. Apple Watch Series 6 Screen Replacement, Determine which procedure to follow: passo 11, imagem 1 %32
    • From this point, the battery removal procedure for the 40 mm watch differs slightly from the 44 mm version.
    • If you're replacing the battery for a 40 mm watch, continue with this step.
    • If you're replacing the battery for a 44 mm watch, continue with this step.
  11. Apple Watch Series 6 Screen Replacement, Pry up the battery: passo 12, imagem 1 %32 Apple Watch Series 6 Screen Replacement, Pry up the battery: passo 12, imagem 2 %32 Apple Watch Series 6 Screen Replacement, Pry up the battery: passo 12, imagem 3 %32
    • The following four steps show how to remove the battery from a 40 mm Apple Watch Series 6.
    • Insert an opening pick between the battery and the Taptic Engine.
    • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the mainboard.
    • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
    • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
  12. Apple Watch Series 6 Screen Replacement, Move the battery: passo 13, imagem 1 %32 Apple Watch Series 6 Screen Replacement, Move the battery: passo 13, imagem 2 %32 Apple Watch Series 6 Screen Replacement, Move the battery: passo 13, imagem 3 %32
    • The battery flex cable is long enough to allow you to place the battery outside the watch case, but avoid straining the cable when you lift the battery out of its recess.
    • Carefully lift and swing the battery out of its recess.
  13. Apple Watch Series 6 Screen Replacement, Disconnect the battery: passo 14, imagem 1 %32 Apple Watch Series 6 Screen Replacement, Disconnect the battery: passo 14, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the battery connector.
    • Remove the battery.
    • Don't reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If you're reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly.
    • Alternatively, remove the old adhesive with high concentration isopropyl alcohol and a lint free cloth and use a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000.
  14. Apple Watch Series 6 Screen Replacement, Pry up the battery: passo 16, imagem 1 %32 Apple Watch Series 6 Screen Replacement, Pry up the battery: passo 16, imagem 2 %32 Apple Watch Series 6 Screen Replacement, Pry up the battery: passo 16, imagem 3 %32
    • The following four steps show how to remove the battery from a 44 mm Apple Watch Series 6.
  15. Apple Watch Series 6 Screen Replacement, Move the battery: passo 17, imagem 1 %32 Apple Watch Series 6 Screen Replacement, Move the battery: passo 17, imagem 2 %32 Apple Watch Series 6 Screen Replacement, Move the battery: passo 17, imagem 3 %32
    • The battery flex cable is long enough to place the battery outside the watch case during the following procedure but avoid straining it when lifting the battery out of its recess.
    • Carefully lift the battery out of its recess and place it outside the watch case opposite to the Taptic Engine.
  16. Apple Watch Series 6 Screen Replacement, Remove the battery connector screw: passo 18, imagem 1 %32
    • Remove the single 1.2 mm-long tri point Y000 screw.
  17. Apple Watch Series 6 Screen Replacement: passo 19, imagem 1 %32 Apple Watch Series 6 Screen Replacement: passo 19, imagem 2 %32
    • Use a pair of tweezers to remove the metal shield covering the battery connector.
  18. Apple Watch Series 6 Screen Replacement: passo 20, imagem 1 %32 Apple Watch Series 6 Screen Replacement: passo 20, imagem 2 %32
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If you are reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly.
  19. Apple Watch Series 6 Screen Replacement, Peel off the protective foil: passo 22, imagem 1 %32 Apple Watch Series 6 Screen Replacement, Peel off the protective foil: passo 22, imagem 2 %32 Apple Watch Series 6 Screen Replacement, Peel off the protective foil: passo 22, imagem 3 %32
    • Use a pair of tweezers to carefully peel the black protective tape off both display connectors.
  20. Apple Watch Series 6 Screen Replacement, Release the display cables: passo 23, imagem 1 %32 Apple Watch Series 6 Screen Replacement, Release the display cables: passo 23, imagem 2 %32 Apple Watch Series 6 Screen Replacement, Release the display cables: passo 23, imagem 3 %32
    • Use the pointed end of a spudger to pry up the lock bars on both ZIF connectors securing the display cables.
  21. Apple Watch Series 6 Screen Replacement: passo 24, imagem 1 %32 Apple Watch Series 6 Screen Replacement: passo 24, imagem 2 %32 Apple Watch Series 6 Screen Replacement: passo 24, imagem 3 %32
    • Use a pair of tweezers to carefully peel off the edges of the sticker which adheres the display and the grounding cable to the rear side of the screen.
  22. Apple Watch Series 6 Screen Replacement: passo 25, imagem 1 %32 Apple Watch Series 6 Screen Replacement: passo 25, imagem 2 %32
    • Use a pair of tweezers to pull both display cables out of the ZIF connectors.
    • Do not pull on the watch assembly, or you may rip the display cable.
  23. Apple Watch Series 6 Screen Replacement, Remove the screen: passo 26, imagem 1 %32
    • Separate the watch assembly and the screen.
Conclusão
To reassemble your Apple Watch Series 6 follow these instructions in reverse order to reattach the screen and the battery.
Apply a little bit of high isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the edges of the watch case and the screen before installing new adhesive.
33 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
185.405 Reputação
Autoria de 680 guias
Equipe
iFixit Membro de iFixit
Community
Membros da 136
Autoria de 15.217 guias
14 comentários
Can anyone tell me what that 3rd cable is (circled red in the pic linked below)? It’s linked to the metal back in the phone?
https://imgur.com/0meecS9
gauntletmm - Responder
I think it is just a grounding wire.
Daniele Carminati -
Did you ever find out what that third wire is?
Antonio Silva Carrillo -
Dommage qu’il n’y ai pas de lien d’une batterie à acheter ainsi qu’un lien pour trouver le joint d’étanchéité.
jeremy_110 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 106
Últimos 7 dias: 825
Últimos 30 dias: 3,930
Duração total: 88,868
