Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Remove the lower case in your Apple TV 1st Generation.
O que você precisa
Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
Repeat the procedure described above until the rubber base has been completely removed.
3 outras pessoas executaram este guia.
Um comentário
This guide may make more sense as a teardown, since its not really showing any repairs or replacements.
