Ir para o conteúdo principal
Apple TV 1st Generation Fan Replacement
O que você precisa
  1. Apple TV 1st Generation Fan Replacement, Lower Case: passo 1, imagem 1 %32
    • Flip the Apple TV over so that the bottom of the unit is facing up.
    • You need to remove the rubber base to get access to the screws.
    • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
    • The rubber base will be hot after heating, take extreme caution while proceeding to avoid personal injury.
    • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
    • The rubber base can tear if the adhesive hasn't been softened enough.
    • Repeat the procedure described above until the rubber base has been completely removed.
    Pergunte ao FixBot
    Comentar
  2. Apple TV 1st Generation Fan Replacement: passo 2, imagem 1 %32
    • Remove the four T10 Torx screws that secure the lower case to the upper case.
    Pergunte ao FixBot
    Comentar
  3. Apple TV 1st Generation Fan Replacement: passo 3, imagem 1 %32
    • Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
    • Be aware that the hard drive is physically attached to the lower case and that a ribbon cable runs from the drive to the logic board in the upper case.
    Pergunte ao FixBot
    Comentar
  4. Apple TV 1st Generation Fan Replacement: passo 4, imagem 1 %32 Apple TV 1st Generation Fan Replacement: passo 4, imagem 2 %32
    • Carefully pull the hard drive data cable straight up from its socket on the logic board.
    • During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board; otherwise, during boot-up you will see a flashing question mark "?".
    Pergunte ao FixBot
    Comentar
  5. Apple TV 1st Generation Fan Replacement, Fan: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • The fan is held in place by three rubber posts.
    • Using a pair of tweezers, squeeze the top of each post and push the post down into the hole. Repeat for all three posts.
    • During reinstallation, it helps to lubricate the rubber posts. Try weaving a string through the holes in the posts to pull them up through the mounting points.
    • Do not excessively pull on the posts, as they may rip.
    Pergunte ao FixBot
    Comentar
  6. Apple TV 1st Generation Fan Replacement: passo 6, imagem 1 %32
    • Using a pair of tweezers, pull the fan connector straight up from its socket on the logic board.
    • Lift and remove the fan out of the upper case.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
ropel
Membro desde: 11/11/09
119 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 18-5, Maness Fall 2009 Membro de Cal Poly, Team 18-5, Maness Fall 2009
CPSU-MANESS-F09S18G5
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 53
Ao todo: 12,515
