Ir para o conteúdo principal
Apple Studio Display M7649 Inverter Replacement
O que você precisa
  1. Apple Studio Display M7649 Inverter Replacement, Stand: passo 1, imagem 1 %32 Apple Studio Display M7649 Inverter Replacement, Stand: passo 1, imagem 2 %32
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
    Pergunte ao FixBot
    Comentar
  2. Apple Studio Display M7649 Inverter Replacement, Panels: passo 2, imagem 1 %32
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
    Pergunte ao FixBot
    Comentar
  3. Apple Studio Display M7649 Inverter Replacement: passo 3, imagem 1 %32
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
    Pergunte ao FixBot
    Comentar
  4. Apple Studio Display M7649 Inverter Replacement: passo 4, imagem 1 %32
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
    Pergunte ao FixBot
    Comentar
  5. Apple Studio Display M7649 Inverter Replacement, Metal EMI Shield: passo 5, imagem 1 %32
    • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
    Pergunte ao FixBot
    Comentar
  6. Apple Studio Display M7649 Inverter Replacement: passo 6, imagem 1 %32
    • Now locate and remove the lone Phillips screw holding the EMI shield to the display
    Pergunte ao FixBot
    Comentar
  7. Apple Studio Display M7649 Inverter Replacement: passo 7, imagem 1 %32 Apple Studio Display M7649 Inverter Replacement: passo 7, imagem 2 %32
    • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
    Pergunte ao FixBot
    Comentar
  8. Apple Studio Display M7649 Inverter Replacement, Inverter: passo 8, imagem 1 %32
    • Remove these three screws holding the board to the display
    Pergunte ao FixBot
    Comentar
  9. Apple Studio Display M7649 Inverter Replacement: passo 9, imagem 1 %32
    • Remove these five cables connection the inverter to the backlights and logic board.
    • Taking note where they connect to for reassembly
    Pergunte ao FixBot
    Comentar
  10. Apple Studio Display M7649 Inverter Replacement: passo 10, imagem 1 %32
    • Remove and replace the inverter
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Andrew Tsao
Membro desde: 01/19/10
186 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 3-20, Maness Winter 2010 Membro de Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 Membros
Autoria de 23 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 63
Ao todo: 7,826
