Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
O que você precisa
Position the Powerbook towards you with the monitor closed.
Press the battery removal latch located on the right side of the front panel.
Gently slide the battery out.
Turn the laptop over and remove the three T8 torx screws from the bottom panel.
Lift up and forward on the front portion of the laptop. Watch out for the ribbon cable, and disconnect it by pulling the cable straight up and out of its connector.
