Ir para o conteúdo principal
Apple PowerBook 520 Memory (RAM) Replacement
O que você precisa
  1. Apple PowerBook 520 Memory (RAM) Replacement, Case: passo 1, imagem 1 %32 Apple PowerBook 520 Memory (RAM) Replacement, Case: passo 1, imagem 2 %32
    • Turn computer over.
    • Remove battery expansion cover and battery.
    Pergunte ao FixBot
    Comentar
  2. Apple PowerBook 520 Memory (RAM) Replacement: passo 2, imagem 1 %32
    • With monitor hinge at the bottom, remove the two top center screws.
    Pergunte ao FixBot
    Comentar
  3. Apple PowerBook 520 Memory (RAM) Replacement: passo 3, imagem 1 %32
    • Remove top left and top right screws.
    Pergunte ao FixBot
    Comentar
  4. Apple PowerBook 520 Memory (RAM) Replacement: passo 4, imagem 1 %32
    • Remove middle left and middle right screws.
    Pergunte ao FixBot
    Comentar
  5. Apple PowerBook 520 Memory (RAM) Replacement: passo 5, imagem 1 %32
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
    Pergunte ao FixBot
    Comentar
  6. Apple PowerBook 520 Memory (RAM) Replacement: passo 6, imagem 1 %32
    • Lift keyboard from bottom and take out of shell.
    Pergunte ao FixBot
    Comentar
  7. Apple PowerBook 520 Memory (RAM) Replacement: passo 7, imagem 1 %32 Apple PowerBook 520 Memory (RAM) Replacement: passo 7, imagem 2 %32 Apple PowerBook 520 Memory (RAM) Replacement: passo 7, imagem 3 %32
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
    Pergunte ao FixBot
    Comentar
  8. Apple PowerBook 520 Memory (RAM) Replacement, Memory (RAM): passo 8, imagem 1 %32
    • Open the panel on back of the device. Remove 2 T8 torque screws.
    Pergunte ao FixBot
    Comentar
  9. Apple PowerBook 520 Memory (RAM) Replacement: passo 9, imagem 1 %32
    • Remove the plastic panel underneath the LCD Screen.
    Pergunte ao FixBot
    Comentar
  10. Apple PowerBook 520 Memory (RAM) Replacement: passo 10, imagem 1 %32
    • Remove the 2 T8 Torx Screws securing the logic board protection plate from the midsection of the logic board protection plate. Remove the T8 Torx Screw from the back of the plate, underneath the hinge.
    Pergunte ao FixBot
    Comentar
  11. Apple PowerBook 520 Memory (RAM) Replacement: passo 11, imagem 1 %32
    • Remove the logic board protection plate.
    Pergunte ao FixBot
    Comentar
  12. Apple PowerBook 520 Memory (RAM) Replacement: passo 12, imagem 1 %32
    • Using a plastic spudger, gently pry up the uppermost board fixture. This is the Memory (RAM).
    Pergunte ao FixBot
    Comentar
  13. Apple PowerBook 520 Memory (RAM) Replacement: passo 13, imagem 1 %32
    • Once the old Memory board is removed, replace it with the new Memory board.
    Pergunte ao FixBot
    Comentar
Conclusão
Tyler
Membro desde: 04/10/11
148 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 20-66, Walters Spring 2011 Membro de Cal Poly, Team 20-66, Walters Spring 2011
CPSU-WALTERS-S11S20G66
4 Membros
Autoria de 3 guias
1Comentário do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 55
Ao todo: 4,029
