O que você precisa
Follow the Apple Lisa Disassembly Guide to remove the Lisa's real panel.
Remove the Lisa's Card Cage.
Locate Lisa's expansion slots.
Locate expansion slot 3.
Pull the metal rod out from slot 3 and rotate 90º clockwise.
Slide the SCSI Card into expansion slot 3.
Rotate the metal rod, as described before, 90º counter-clockwise and push in to secure the Lisa DAC.
The SCSI card includes 1 internal connector and 1 external connector.
The internal connector is used for connecting a hard disk.
If you intend to connect a hard disk then connect it now.
Pin 1 is marked.
The SCSI Card can also be cut to accommodate a Card Cage fan upon order request.
The SCSI Card requires MacWorks Plus II.
To use devices connected to the SCSI card please refer to the device's manual for proper device installation.
This SCSI card was installed to use an Apple External SCSI CD-ROM Drive.
