Ir para o conteúdo principal
Apple Lisa Disassembly
O que você precisa
  1. Apple Lisa Disassembly, Prepare Workspace: passo 1, imagem 1 %32
    • Place the Lisa on a safe/sturdy surface.
  2. Apple Lisa Disassembly, Removing Front Panel: passo 2, imagem 1 %32 Apple Lisa Disassembly, Removing Front Panel: passo 2, imagem 2 %32
    • Press the two tabs underneath to release the panel.
  3. Apple Lisa Disassembly, Remove Drive Cage: passo 3, imagem 1 %32
    • Release the thumbscrew underneath the drive cage and the cage will pull out. Disconnect drive wires while the cage is being removed.
  4. Apple Lisa Disassembly, Remove Back Panel: passo 4, imagem 1 %32 Apple Lisa Disassembly, Remove Back Panel: passo 4, imagem 2 %32
    • Twist thumbscrews on the back to release the panel. Pull panel up to remove.
  5. Apple Lisa Disassembly, Remove Power Supply: passo 5, imagem 1 %32 Apple Lisa Disassembly, Remove Power Supply: passo 5, imagem 2 %32 Apple Lisa Disassembly, Remove Power Supply: passo 5, imagem 3 %32
    • Release the thumbscrew on the power supply. Pull out the power supply.
  6. Apple Lisa Disassembly, Remove Cardcage: passo 6, imagem 1 %32 Apple Lisa Disassembly, Remove Cardcage: passo 6, imagem 2 %32
    • Grab the card cage at the location shown and pull out.
  7. Apple Lisa Disassembly, Remove Top: passo 7, imagem 1 %32 Apple Lisa Disassembly, Remove Top: passo 7, imagem 2 %32
    • Unscrew two philips screws on the ceiling of where the card cage was.
  8. Apple Lisa Disassembly, Remove Power Switch: passo 8, imagem 1 %32 Apple Lisa Disassembly, Remove Power Switch: passo 8, imagem 2 %32
    • Release two screws and release the ribbon cable.
  9. Apple Lisa Disassembly, Remove Right Panel: passo 9, imagem 1 %32 Apple Lisa Disassembly, Remove Right Panel: passo 9, imagem 2 %32 Apple Lisa Disassembly, Remove Right Panel: passo 9, imagem 3 %32
    • Remove all screws shown.
  10. Apple Lisa Disassembly, Remove Left Panel: passo 10, imagem 1 %32 Apple Lisa Disassembly, Remove Left Panel: passo 10, imagem 2 %32
  11. Apple Lisa Disassembly, Remove Feet Panel: passo 11, imagem 1 %32
  12. Apple Lisa Disassembly, Remove Bottom Pannel: passo 12, imagem 1 %32
  13. Apple Lisa Disassembly, CRT: passo 13, imagem 1 %32
    • I am not a certified CRT technician so I am not suppling steps on how to remove it although here is a photo of the innards.
  14. Apple Lisa Disassembly, Remove Cards: passo 14, imagem 1 %32 Apple Lisa Disassembly, Remove Cards: passo 14, imagem 2 %32 Apple Lisa Disassembly, Remove Cards: passo 14, imagem 3 %32
    • Pull up on the tabs to remove cards.
  15. Apple Lisa Disassembly, Remove Card Mount: passo 15, imagem 1 %32 Apple Lisa Disassembly, Remove Card Mount: passo 15, imagem 2 %32 Apple Lisa Disassembly, Remove Card Mount: passo 15, imagem 3 %32
Conclusão
4 outras pessoas executaram este guia.
LisaGuide
Membro desde: 12/30/18
1.833 Reputação
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 26
Ao todo: 2,651
