Ir para o conteúdo principal
Apple LED Cinema Display 27" LED Panel Replacement
O que você precisa
  1. Apple LED Cinema Display 27" LED Panel Replacement, LED panel: passo 1, imagem 1 %32 Apple LED Cinema Display 27" LED Panel Replacement, LED panel: passo 1, imagem 2 %32 Apple LED Cinema Display 27" LED Panel Replacement, LED panel: passo 1, imagem 3 %32
    • Before beginning any work on your Mac: Unplug the computer and wait for 2 minutes in order for the power supply's capacitors to discharge.
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply.
    • The all-in-one cable located underneath the power cable can NOT get disconnected from the rest of the enclosure.
    Pergunte ao FixBot
    Comentar
  2. Apple LED Cinema Display 27" LED Panel Replacement: passo 2, imagem 1 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 2, imagem 2 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 2, imagem 3 %32
    • Glass panel can be removed in various ways:
    • Lay the unit on its back and press clean suction cups in opposite corners on the glass panel, or...
    • Lay the unit on its back and press clean suction cups on top.
    • Lift the glass panel up and off.
    Pergunte ao FixBot
    Comentar
  3. Apple LED Cinema Display 27" LED Panel Replacement: passo 3, imagem 1 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 3, imagem 2 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 3, imagem 3 %32
    • First Steps Remove the glass panel as shown on step 2.
    • Upon disassembly, handle the LED panel only from the metal railings on either side and avoid touching the panel as much as possible.
    • Do not press on the front surface of the LED panel when handling, as this could cause the pixels from the panel to malfunction and/or stop working.
    Pergunte ao FixBot
    Comentar
  4. Apple LED Cinema Display 27" LED Panel Replacement: passo 4, imagem 1 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 4, imagem 2 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 4, imagem 3 %32
    • Remove the twelve, 10 mm Torx T10 screws around the border of the display frame.
    • Be sure not to overtighten the LED screws during reassembly, as it could cause light leakage after the unit is reassembled.
    Pergunte ao FixBot
    Comentar
  5. Apple LED Cinema Display 27" LED Panel Replacement: passo 5, imagem 1 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 5, imagem 2 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 5, imagem 3 %32
    • Use the black tabs to raise the bottom edge of the LCD a few inches to access the cables inside.
    • Tilt the display up no more than 4 inches (10 cm). Pulling the display too far could damage the cables or connectors.
    Pergunte ao FixBot
    Comentar
  6. Apple LED Cinema Display 27" LED Panel Replacement: passo 6, imagem 1 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 6, imagem 2 %32
    • Avoid coming in close contact or touching any components of the Power Supply.
    • Looking into the gap under the LCD, disconnect four (4) cables:
    • DisplayPort
    • Function
    • Ground pin
    • LED backlight driver
    • Verify that all cables are firmly seated into connectors during reassembly. An insecure cable connection can cause image flicker.
    Pergunte ao FixBot
    Comentar
  7. Apple LED Cinema Display 27" LED Panel Replacement: passo 7, imagem 1 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 7, imagem 2 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 7, imagem 3 %32
    • Peel back the mylar and foil tape on the DisplayPort cable on the back of the LED panel.
    • Squeeze the sides of connector and pull it out.
    • Make sure the 24 pin cable is correctly aligned with the LED panel upon reassembly.
    Pergunte ao FixBot
    Comentar
  8. Apple LED Cinema Display 27" LED Panel Replacement: passo 8, imagem 1 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 8, imagem 2 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 8, imagem 3 %32
    • Squeeze the sides of the function cable connector on the top left edge of the logic board and pull it straight out.
    • Make sure to align the function cable correctly with the logic board during reassembly.
    Pergunte ao FixBot
    Comentar
  9. Apple LED Cinema Display 27" LED Panel Replacement: passo 9, imagem 1 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 9, imagem 2 %32
    • Close-up of the ground cable at top left of logic board. Remove the 10 mm Torx T10 screw from top left corner of logic board.
    • Disconnect the ground cable.
    • Avoid touching the double pins on the top left corner of the logic board with a screwdriver.
    Pergunte ao FixBot
    Comentar
  10. Apple LED Cinema Display 27" LED Panel Replacement: passo 10, imagem 1 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 10, imagem 2 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 10, imagem 3 %32
    • Pinch the LED backlight driver cable on the underside of the center right edge of the logic board and pull straight out.
    • Avoid putting force on the logic board to bend as deformation of a logic board can cause issues.
    Pergunte ao FixBot
    Comentar
  11. Apple LED Cinema Display 27" LED Panel Replacement: passo 11, imagem 1 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 11, imagem 2 %32 Apple LED Cinema Display 27" LED Panel Replacement: passo 11, imagem 3 %32
    • Handle the LCD panel by the edges and lift it upwards until it separates from the rest of the enclosure.
    • This guide can be followed in reserve in order to perform an installation and reassembly of the LED panel to the rest of the enclosure.
    Pergunte ao FixBot
    Comentar
Conclusão
In order to put everything back to its original place, we will need the new LCD panel and to follow the above steps in reverse.
8 outras pessoas executaram este guia.
Documentos anexados
Iason Kotakis
Membro desde: 01/10/21
393 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 64
Últimos 30 dias: 295
Ao todo: 17,332
