Ir para o conteúdo principal
Apple IIc Power Converter Replacement
O que você precisa
  1. Apple IIc Power Converter Replacement, Disassembling Apple IIc Cover: passo 1, imagem 1 %32 Apple IIc Power Converter Replacement, Disassembling Apple IIc Cover: passo 1, imagem 2 %32
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Apple IIc Power Converter Replacement: passo 2, imagem 1 %32 Apple IIc Power Converter Replacement: passo 2, imagem 2 %32
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
    Pergunte ao FixBot
    Comentar
  3. Apple IIc Power Converter Replacement: passo 3, imagem 1 %32 Apple IIc Power Converter Replacement: passo 3, imagem 2 %32
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    Pergunte ao FixBot
    Comentar
  4. Apple IIc Power Converter Replacement: passo 4, imagem 1 %32 Apple IIc Power Converter Replacement: passo 4, imagem 2 %32
    • Lift the handle straight up to remove.
    Pergunte ao FixBot
    Comentar
  5. Apple IIc Power Converter Replacement, Power Converter: passo 5, imagem 1 %32
    • Remove the two 7.7mm length Phillips screws that secure the power converter.
    Pergunte ao FixBot
    Comentar
  6. Apple IIc Power Converter Replacement: passo 6, imagem 1 %32 Apple IIc Power Converter Replacement: passo 6, imagem 2 %32
    • Grab the back of the power supply and pull out while lifting up so that it will clear the other components.
    • The power supply can be difficult to remove so be careful not to bend or damage any nearby components while you pull out the power supply.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Josiah
Membro desde: 10/06/11
658 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 21-23, Maness Fall 2011 Membro de Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 55
Ao todo: 4,945
