Ir para o conteúdo principal
Apple IIc Keyboard Replacement
O que você precisa
  1. Apple IIc Keyboard Replacement, Disassembling Apple IIc Cover: passo 1, imagem 1 %32 Apple IIc Keyboard Replacement, Disassembling Apple IIc Cover: passo 1, imagem 2 %32
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Apple IIc Keyboard Replacement: passo 2, imagem 1 %32 Apple IIc Keyboard Replacement: passo 2, imagem 2 %32
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
    Pergunte ao FixBot
    Comentar
  3. Apple IIc Keyboard Replacement: passo 3, imagem 1 %32 Apple IIc Keyboard Replacement: passo 3, imagem 2 %32
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    Pergunte ao FixBot
    Comentar
  4. Apple IIc Keyboard Replacement: passo 4, imagem 1 %32 Apple IIc Keyboard Replacement: passo 4, imagem 2 %32
    • Lift the handle straight up to remove.
    Pergunte ao FixBot
    Comentar
  5. Apple IIc Keyboard Replacement, Keyboard: passo 5, imagem 1 %32 Apple IIc Keyboard Replacement, Keyboard: passo 5, imagem 2 %32
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 21-23, Maness Fall 2011 Membro de Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 48
Ao todo: 4,016
