Ir para o conteúdo principal
Apex Tablet 7 Camera Replacement
O que você precisa
    1. Apex Tablet 7 Camera Replacement, Back Panel: passo 1, imagem 1 %32
      • Unscrew the two 2.70 mm Phillips #00 screws on the side of the tablet that has the buttons and the headphone jack (bottom side when holding upright).
      Pergunte ao FixBot
      Comentar
    2. Apex Tablet 7 Camera Replacement: passo 2, imagem 1 %32 Apex Tablet 7 Camera Replacement: passo 2, imagem 2 %32
      • CAUTION: When removing the back panel of the tablet, take caution around the speaker. This is located in the lower right corner when looking at the back of the tablet. There are two wires inside connecting the tablet back panel to the device itself and this connection may be severed if the back is pulled off without care.
      • This connection is shown in red on the pictures.
      Pergunte ao FixBot
      Comentar
    3. Apex Tablet 7 Camera Replacement: passo 3, imagem 1 %32 Apex Tablet 7 Camera Replacement: passo 3, imagem 2 %32
      • Slide a plastic opening tool in between the edge of the back panel and the the top edge of the device.
      • Run the plastic opening tool along the sides of the tablet while keeping it in the crack between the tablet and the back panel to create an opening.
      Pergunte ao FixBot
      Comentar
    4. Apex Tablet 7 Camera Replacement: passo 4, imagem 1 %32
      • Apply pressure using your hand to pop the back panel off slowly, taking extra care around the speaker connection.
      Pergunte ao FixBot
      Comentar
    5. Apex Tablet 7 Camera Replacement: passo 5, imagem 1 %32
      • The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
      Pergunte ao FixBot
      Comentar
    1. Apex Tablet 7 Camera Replacement, Camera: passo 6, imagem 1 %32 Apex Tablet 7 Camera Replacement, Camera: passo 6, imagem 2 %32
      • Gently remove the black tape covering the camera and circuit board. The tape will be connected to a foamy block on the back of the actual camera component.
      Pergunte ao FixBot
      Comentar
    2. Apex Tablet 7 Camera Replacement: passo 7, imagem 1 %32
      • Flip the black latch over the gold cable to the upright position in order to release the cable.
      Pergunte ao FixBot
      Comentar
    3. Apex Tablet 7 Camera Replacement: passo 8, imagem 1 %32
      • Carefully remove the cable from the circuit by pulling it straight out.
      Pergunte ao FixBot
      Comentar
    4. Apex Tablet 7 Camera Replacement: passo 9, imagem 1 %32
      • Pull out the camera. There should not be any more connections holding it in place.
      • Reconnect the replacement camera.
      Pergunte ao FixBot
      Comentar
Conclusão
To place the new part and reassemble your device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Equipe
Baylor, Team 2-2, Grigsby Spring 2015 Membro de Baylor, Team 2-2, Grigsby Spring 2015
BU-GRIGSBY-S15S2G2
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 28
Ao todo: 721
