Ir para o conteúdo principal
Apalus Digital Hair Straightening Brush LCD Screen Replacement
O que você precisa
  1. Apalus Digital Hair Straightening Brush LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush LCD Screen Replacement: passo 2, imagem 1 %32
    • Now that the screws are taken out, remove the backside of the comb.
  3. Apalus Digital Hair Straightening Brush LCD Screen Replacement: passo 3, imagem 1 %32
    • Unplug the power cord from the insert inside of the brush.
    • Be careful not to tug on the wires. Hold the insert when removing the power cord.
  4. Apalus Digital Hair Straightening Brush LCD Screen Replacement: passo 4, imagem 1 %32
    • Remove the circuit board and heating element from the handle.
    • This will make it easier to work on for later steps.
  5. Apalus Digital Hair Straightening Brush LCD Screen Replacement: passo 5, imagem 1 %32
    • Locate the LED screen on the top side of the circuit board
  6. Apalus Digital Hair Straightening Brush LCD Screen Replacement: passo 6, imagem 1 %32
    • Flip the circuit board to start soldering.
  7. Apalus Digital Hair Straightening Brush LCD Screen Replacement: passo 7, imagem 1 %32 Apalus Digital Hair Straightening Brush LCD Screen Replacement: passo 7, imagem 2 %32
    • Using the soldering tool, melt the solder holding the LCD screen on the circuit board.
    • The screen is soldered in 11 places on the circuit board. Melt each of these points and remove the screen.
    • Soldering Technique Guide
  8. Apalus Digital Hair Straightening Brush LCD Screen Replacement: passo 8, imagem 1 %32 Apalus Digital Hair Straightening Brush LCD Screen Replacement: passo 8, imagem 2 %32
    • Now that the LCD screen is removed, use a soldering tool and solder to install the new screen on the circuit board.
    • Solder at the same 11 points where you previously melted to remove the screen.
Conclusão
Malak
Membro desde: 11/06/17
101 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G3, Harley Fall 2017 Membro de IUPUI, Team S1-G3, Harley Fall 2017
IUPUI-HARLEY-F17S1G3
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 499
