Ir para o conteúdo principal
Apalus Digital Hair Straightening Brush Heating Element Replacement
O que você precisa
  1. Apalus Digital Hair Straightening Brush Heating Element Replacement, Heating Element: passo 1, imagem 1 %32
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush Heating Element Replacement: passo 2, imagem 1 %32
    • Turn comb over so the bristles are facing down.
    • Remove backside of the comb and place aside.
  3. Apalus Digital Hair Straightening Brush Heating Element Replacement: passo 3, imagem 1 %32
    • Unplug the power cord from the connector inside of the brush.
  4. Apalus Digital Hair Straightening Brush Heating Element Replacement: passo 4, imagem 1 %32
    • Remove the circuit board and heating element from the handle.
    • This will provide easy access to the necessary components.
  5. Apalus Digital Hair Straightening Brush Heating Element Replacement: passo 5, imagem 1 %32
    • Remove the four 6mm Phillips #2 screws holding the heat shield onto the back side of the bristles.
  6. Apalus Digital Hair Straightening Brush Heating Element Replacement: passo 6, imagem 1 %32
    • There are 4 solder points of the heating element located on the LCD side of the circuit board.
    • Desolder these four connections using a soldering iron.
    • Note which wires go to each of the connection points.
    • Soldering Technique Guide
  7. Apalus Digital Hair Straightening Brush Heating Element Replacement: passo 7, imagem 1 %32
    • Solder the new heating element to the same connection points as they were removed from.
Conclusão
Aaron Brysch
Membro desde: 11/06/17
231 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G3, Harley Fall 2017 Membro de IUPUI, Team S1-G3, Harley Fall 2017
IUPUI-HARLEY-F17S1G3
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 2,190
