Ir para o conteúdo principal
Apalus Digital Hair Straightening Brush Buttons Replacement
O que você precisa
  1. Apalus Digital Hair Straightening Brush Buttons Replacement, Buttons on the side of the brush: passo 1, imagem 1 %32
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush Buttons Replacement: passo 2, imagem 1 %32
    • Now that the screws are taken out, remove the backside of the comb.
  3. Apalus Digital Hair Straightening Brush Buttons Replacement: passo 3, imagem 1 %32
    • Unplug the power cord from the insert inside of the brush.
    • Be careful not to tug on the wires. Hold the insert when removing the power cord.
  4. Apalus Digital Hair Straightening Brush Buttons Replacement: passo 4, imagem 1 %32
    • Remove the circuit board and heating element from the handle.
    • This will make it easier to work on for later steps.
  5. Apalus Digital Hair Straightening Brush Buttons Replacement: passo 5, imagem 1 %32
    • Locate the three buttons on the bottom side of the circuit board.
  6. Apalus Digital Hair Straightening Brush Buttons Replacement: passo 6, imagem 1 %32
    • Each button is soldered in four places on the circuit board. Using the soldering tool, melt each of these four points and remove the dysfunctional buttons.
    • You may have to bend the dark red capacitor out of the way to reach the soldering points.
    • Soldering Technique Guide
  7. Apalus Digital Hair Straightening Brush Buttons Replacement: passo 7, imagem 1 %32
    • Now that the dysfunctional buttons are removed, use a soldering tool and solder to install the new buttons on the circuit board.
    • Solder at the same four points as when previously melting these points to remove the buttons.
Conclusão
Uma outra pessoa concluiu este guia.
Aaron Brysch
Membro desde: 11/06/17
231 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G3, Harley Fall 2017 Membro de IUPUI, Team S1-G3, Harley Fall 2017
IUPUI-HARLEY-F17S1G3
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 669
