Ir para o conteúdo principal
Aoson R103 Speakers Replacement
O que você precisa
  1. Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: passo 1, imagem 1 %32 Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: passo 1, imagem 2 %32 Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: passo 1, imagem 3 %32
    • Turn off the device using the power button.
    • Using fingernails/a pry tool, separate the back panel of the device. This may decent force as they are connected by push tabs.
    • Be careful not to drop the device when separating, this could cause permanent damage.
    • This will expose the motherboard of the device.
  2. Aoson R103 Speakers Replacement: passo 2, imagem 1 %32 Aoson R103 Speakers Replacement: passo 2, imagem 2 %32
    • Use your fingers to unclip the ribbon connecter and then pull the ribbon out of the connector.
    • This ribbon connects the power button and stops the device from turning on; allowing further procedure.
  3. Aoson R103 Speakers Replacement, Speakers: passo 3, imagem 1 %32 Aoson R103 Speakers Replacement, Speakers: passo 3, imagem 2 %32 Aoson R103 Speakers Replacement, Speakers: passo 3, imagem 3 %32
    • The motherboard connections to the speaker are circled, they will be needed later.
    • The two speakers are circled in orange, they are attached to a plastic piece via a screw.
    • The 4.0mm long philips-head 00 screw will be disconnected at the Boxed area where the plastic disconnects.
    • Be careful not to disconnect the back ground wire when taking the plastic off.
  4. Aoson R103 Speakers Replacement: passo 4, imagem 1 %32 Aoson R103 Speakers Replacement: passo 4, imagem 2 %32
    • The box contains the four (4) soldering connections for the two speakers. Unsolder the old speakers and solder the new speakers in.
    • Be sure to match up the appropriately placed speaker to its correct positive or negative node. mixing these up could distort audio or fry the speakers.
    • Note: solder over a piece of paper where you can mark each node with a red or black marker to denote positive and negative nodes for the left or right speaker.
Conclusão
Uma outra pessoa concluiu este guia.
Louis
Membro desde: 02/14/23
208 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 180
