Ir para o conteúdo principal
Answering Machine Speaker Replacement
O que você precisa
  1. Answering Machine Speaker Replacement, Base: passo 1, imagem 1 %32
    • Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
    • Use a screwdriver to remove all four 11mm Phillips #0 screws.
  2. Answering Machine Speaker Replacement: passo 2, imagem 1 %32 Answering Machine Speaker Replacement: passo 2, imagem 2 %32
    • Locate an easy seam for entry and insert the metal spudger to separate the plastic. Use the spudger in multiple places if necessary.
    • Opening the base may require exerting significant force as it is bound together tightly. This step can be dangerous.
    • The spudger is designed to make this step easier.
  3. Answering Machine Speaker Replacement, Answering Machine Speaker: passo 3, imagem 1 %32 Answering Machine Speaker Replacement, Answering Machine Speaker: passo 3, imagem 2 %32
    • Locate the speaker at the top left of the base as pictured. It is the silver, conical component. Two 7mm Phillips #0 screws hold the speaker in place.
    • Use a screwdriver to remove the two 7mm Phillips #0 screws.
  4. Answering Machine Speaker Replacement: passo 4, imagem 1 %32
    • Finish speaker removal by cutting both the black and red wires.
  5. Answering Machine Speaker Replacement: passo 5, imagem 1 %32
Conclusão
Troy Chester
Membro desde: 09/29/16
84 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 3-3, Harley Fall 2016 Membro de IUPUI, Team 3-3, Harley Fall 2016
IUPUI-HARLEY-F16S3G3
4 Membros
Autoria de 17 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 22
Ao todo: 733
