Ir para o conteúdo principal
Anne Pro 2 Keyboard Keycaps Replacement
O que você precisa
    1. Anne Pro 2 Keyboard Keycaps Replacement, Keycaps: passo 1, imagem 1 %32
      • Set the keyboard down on a flat surface. Make sure it is turned off and is not connected to a power source.
      Pergunte ao FixBot
      Comentar
    2. Anne Pro 2 Keyboard Keycaps Replacement: passo 2, imagem 1 %32 Anne Pro 2 Keyboard Keycaps Replacement: passo 2, imagem 2 %32 Anne Pro 2 Keyboard Keycaps Replacement: passo 2, imagem 3 %32
      • Use the keycap remover to remove the key caps from left to right.
      • Remove the smaller keycaps first so the surrounding larger caps can be removed more easily.
      Pergunte ao FixBot
      Comentar
    3. Anne Pro 2 Keyboard Keycaps Replacement: passo 3, imagem 1 %32 Anne Pro 2 Keyboard Keycaps Replacement: passo 3, imagem 2 %32
      • Use the compressed air to remove all dust and hair from the keyboard.
      • Focus on the red key switches to make sure all dust and hair are removed from inside.
      Pergunte ao FixBot
      Comentar
    4. Anne Pro 2 Keyboard Keycaps Replacement: passo 4, imagem 1 %32
      • New replacement keycaps can be used here, but if you see no damage to older keycaps they can be re-used.
      • Use the keycap remover to set in the keycaps starting from the bottom to the top.
      Pergunte ao FixBot
      Comentar
    5. Anne Pro 2 Keyboard Keycaps Replacement: passo 5, imagem 1 %32
      • Inspect the final product, making sure all keycaps are back in the right place and functioning.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
Uma outra pessoa concluiu este guia.
Omar Sukkar
Membro desde: 11/24/20
145 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 57
Ao todo: 2,740
