Introdução
This guide outlines the steps in fully removing the LCD facial display of the Anki Vector. Such a procedure should be executed only if none of the solutions on the Anki troubleshooting guide were unsuccessful.
While disassembling Vector, make sure to check for loose cables/connectors and other broken parts. Often times these can be fixed without replacing the entire display.
Be careful to not rip the rubber sheet on the back of the display while removing or working with it, as it is very delicate and easy to tear.
O que você precisa
Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
Repeat this step on the other side.
8 outras pessoas executaram este guia.
26Comentários do guia
Any idea where to get the proper displays ?
This is great information, but where can I buy the display?
yeah I can’t find it anywhere.
Does anyone have a line on display parts source?
