Ir para o conteúdo principal
Anki Vector Infrared Sensor Replacement
O que você precisa
    1. Anki Vector Infrared Sensor Replacement, Belts: passo 1, imagem 1 %32
      • Raise Vector's arms above his head.
      Pergunte ao FixBot
      Comentar
    2. Anki Vector Infrared Sensor Replacement: passo 2, imagem 1 %32 Anki Vector Infrared Sensor Replacement: passo 2, imagem 2 %32
      • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
      • Repeat on the other side.
      Pergunte ao FixBot
      Comentar
    1. Anki Vector Infrared Sensor Replacement, Infrared Sensor: passo 3, imagem 1 %32 Anki Vector Infrared Sensor Replacement, Infrared Sensor: passo 3, imagem 2 %32
      • Pull each front wheel cover off.
      • This will require a good amount of force due to the three clips holding it in place.
      Pergunte ao FixBot
      Comentar
    2. Anki Vector Infrared Sensor Replacement: passo 4, imagem 1 %32 Anki Vector Infrared Sensor Replacement: passo 4, imagem 2 %32
      • Unscrew the wheel with the Phillips #00 screwdriver and gently remove it.
      Pergunte ao FixBot
      Comentar
    3. Anki Vector Infrared Sensor Replacement: passo 5, imagem 1 %32
      • Unscrew the two body screws beneath the wheel using the same screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Anki Vector Infrared Sensor Replacement: passo 6, imagem 1 %32 Anki Vector Infrared Sensor Replacement: passo 6, imagem 2 %32
      • Gently pull off the front panel to unplug the Infrared sensor.
      • Be careful when pulling off the front panel. The Sensor is connected by wires to both the panel and the device.
      Pergunte ao FixBot
      Comentar
Conclusão
Shay Takei
Membro desde: 04/16/19
1.831 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S2-G6, Maness Spring 2019 Membro de Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 33
Ao todo: 1,119
