Ir para o conteúdo principal
Anki Cozmo Battery Replacement
O que você precisa
    1. Anki Cozmo Battery Replacement, Speaker: passo 1, imagem 1 %32 Anki Cozmo Battery Replacement, Speaker: passo 1, imagem 2 %32
      • Remove the two black rubber treads from the wheels using your hands to pull them off.
      Pergunte ao FixBot
      Comentar
    2. Anki Cozmo Battery Replacement: passo 2, imagem 1 %32 Anki Cozmo Battery Replacement: passo 2, imagem 2 %32
      • Remove the white hubcap from each of the four wheels using the metal spudger to pry them off.
      • There are four white hubcaps removed in this step. If your Cozmo is a different color, the hubcaps will also be the same color.
      Pergunte ao FixBot
      Comentar
    3. Anki Cozmo Battery Replacement: passo 3, imagem 1 %32
      • Remove the 7.5 mm screw in the middle of each of the four red wheels using a JIS #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Anki Cozmo Battery Replacement: passo 4, imagem 1 %32
      • Remove the red hubcaps from each of the four wheels using your hands and fingers to pull them off.
      Pergunte ao FixBot
      Comentar
    5. Anki Cozmo Battery Replacement: passo 5, imagem 1 %32
      • Remove the 5.5 mm screw on the right side of the front gold bumper using a JIS #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    6. Anki Cozmo Battery Replacement: passo 6, imagem 1 %32 Anki Cozmo Battery Replacement: passo 6, imagem 2 %32
      • Remove the 5.5 mm screw on the left side of the front gold bumper using a JIS #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    7. Anki Cozmo Battery Replacement: passo 7, imagem 1 %32 Anki Cozmo Battery Replacement: passo 7, imagem 2 %32
      • Remove the front gold bumper using your hands and fingers to pull it off.
      Pergunte ao FixBot
      Comentar
    8. Anki Cozmo Battery Replacement: passo 8, imagem 1 %32 Anki Cozmo Battery Replacement: passo 8, imagem 2 %32
      • Remove the two 5.5 mm screws that lay deep on the right (your right when you face the front of the robot) side of the gold body using a JIS #0 screwdriver.
      • One screw is towards the front wheel and one screw is towards the back wheel.
      Pergunte ao FixBot
      Comentar
    9. Anki Cozmo Battery Replacement: passo 9, imagem 1 %32 Anki Cozmo Battery Replacement: passo 9, imagem 2 %32
      • The thinner upper arms have a small hole on the bottom of the rotating hub, allowing you to press the retaining clip in while pulling the arm outward to remove it.
      • The thicker lower arms have indexed slots that align with retaining tabs internally. Rotate the arm to its topmost position, where it touches the upper axle. Apply gentle pressure outward to remove the arm.
      • Do not force the arms with a spudger as shown in the photo! This can easily break the retaining tabs!
      • The short arm on the right side of the body has a long white spring attached to it that runs through the center of the body.
      Pergunte ao FixBot
      Comentar
    10. Anki Cozmo Battery Replacement: passo 10, imagem 1 %32 Anki Cozmo Battery Replacement: passo 10, imagem 2 %32 Anki Cozmo Battery Replacement: passo 10, imagem 3 %32
      • Remove the long white spring that is attached to the right short arm from the center of the body using your hands and fingers to pull it out.
      Pergunte ao FixBot
      Comentar
    11. Anki Cozmo Battery Replacement: passo 11, imagem 1 %32 Anki Cozmo Battery Replacement: passo 11, imagem 2 %32
      • Pop off the two red square fascia from both sides of the white head using the metal spudger to pop them off.
      Pergunte ao FixBot
      Comentar
    12. Anki Cozmo Battery Replacement: passo 12, imagem 1 %32
      • Remove the two 5.5 mm screws from the right side of the white head using a JIS #0 screwdriver.
      Pergunte ao FixBot
      Comentar
    13. Anki Cozmo Battery Replacement: passo 13, imagem 1 %32 Anki Cozmo Battery Replacement: passo 13, imagem 2 %32
      • Remove the right side of the white head using your hands and fingers to pull it off.
      • Do not unscrew or remove the two screws or the two white springs from the left side of the white head.
      Pergunte ao FixBot
      Comentar
    14. Anki Cozmo Battery Replacement: passo 14, imagem 1 %32
      • Pop out the black cover screen from the left side of the head using your hands and fingers to pull it out.
      Pergunte ao FixBot
      Comentar
    15. Anki Cozmo Battery Replacement: passo 15, imagem 1 %32
      • Remove the left side of the white head, along with the two short white springs that are attached to it, using your hands and fingers to pull them off.
      Pergunte ao FixBot
      Comentar
    16. Anki Cozmo Battery Replacement: passo 16, imagem 1 %32 Anki Cozmo Battery Replacement: passo 16, imagem 2 %32
      • Unplug the black LED camera screen and the white and gold speaker from the small white plug in the center of the body using your hands and fingers to pull it off.
      • The camera and the speaker are attached to each other. They are removed in the same step.
      Pergunte ao FixBot
      Comentar
    1. Anki Cozmo Battery Replacement, Battery: passo 17, imagem 1 %32
      • Remove the two 5.5 mm screws from the red trim that was behind the white head using a JIS #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Anki Cozmo Battery Replacement: passo 18, imagem 1 %32
      • Remove the red trim that was behind the white head using your hands and fingers to pull it off.
      Pergunte ao FixBot
      Comentar
    3. Anki Cozmo Battery Replacement: passo 19, imagem 1 %32
      • Pop off the white and gold back trim that is connected to the LED panel using your hands and fingers to pull it off.
      • Do not unplug and remove the white and gold back trim. Leave the white and gold back trim hanging.
      Pergunte ao FixBot
      Comentar
    4. Anki Cozmo Battery Replacement: passo 20, imagem 1 %32
      • Remove the 7.5 mm screw from the gold bar in the center of the body using a JIS #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Anki Cozmo Battery Replacement: passo 21, imagem 1 %32 Anki Cozmo Battery Replacement: passo 21, imagem 2 %32 Anki Cozmo Battery Replacement: passo 21, imagem 3 %32
      • Pry apart the two halves of the gold body using your hands and fingers to pull them apart from each other.
      Pergunte ao FixBot
      Comentar
    6. Anki Cozmo Battery Replacement: passo 22, imagem 1 %32 Anki Cozmo Battery Replacement: passo 22, imagem 2 %32 Anki Cozmo Battery Replacement: passo 22, imagem 3 %32
      • Unplug and remove the silver battery from the bottom of the charging panel using your hands and fingers to pull it out.
      • Keep track of where the red and black wires get plugged into for reassembly.
      Pergunte ao FixBot
      Comentar
Conclusão
19 outras pessoas executaram este guia.
Marisa Gay
Membro desde: 10/28/21
782 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-8, Gulbrandsen Fall 2021 Membro de UMass Dartmouth, Team 4-8, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G8
3 Membros
Autoria de 15 guias
18Comentários do guia
To detach the battery, don’t forget to remove the solder from the two points where the battery connects. (For Cozmo Collectors edition w/ press-able backpack button)
Kaptyn - Responder Compartilhar
The soldering steps are wrong. Don't desolder the speaker, but do desolder the battery.
Scott - Responder Compartilhar
Step 9 should be operated while the arm is at his maximum height.
Eric Hueber - Responder Compartilhar
Yes, excellent tip!
ticom3 - Responder Compartilhar
Step 9 is the hardest from far ! And you'll easily get hurt by your tools. Moreover, reassembling cozmo will certainly deteriorate it. You should operate the big part of the arm (the lower) while the arm is at his maximum height. To do so, disassemble the white part of the fork by prying it down. Then remove the 2 screws of the upper arms, and remove these arms. Eventually, the big arm is easy to remove (or to reassemble).
Comentar
Visualizações:
Últimas 24 horas: 26
Últimos 7 dias: 121
Últimos 30 dias: 468
Ao todo: 31,188
