Ir para o conteúdo principal
Anker Soundcore Select Pro A 3126 Button Panel Replacement
O que você precisa
  1. Anker Soundcore Select Pro A 3126 Button Panel Replacement, Button Panel: passo 1, imagem 1 %32 Anker Soundcore Select Pro A 3126 Button Panel Replacement, Button Panel: passo 1, imagem 2 %32
    • Use a spudger to remove each side speaker cover by inserting it in the crevice and using moderate force to pry them off.
    Pergunte ao FixBot
    Comentar
  2. Anker Soundcore Select Pro A 3126 Button Panel Replacement: passo 2, imagem 1 %32 Anker Soundcore Select Pro A 3126 Button Panel Replacement: passo 2, imagem 2 %32
    • Insert a spudger into the space between the grille and speaker frame to pry the mesh grille covering the front speakers.
    Pergunte ao FixBot
    Comentar
  3. Anker Soundcore Select Pro A 3126 Button Panel Replacement: passo 3, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the eight 12.7 mm screws securing the front cover.
    Pergunte ao FixBot
    Comentar
  4. Anker Soundcore Select Pro A 3126 Button Panel Replacement: passo 4, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove the eight 8.75 mm screws around the corners of each speaker.
    Pergunte ao FixBot
    Comentar
  5. Anker Soundcore Select Pro A 3126 Button Panel Replacement: passo 5, imagem 1 %32
    • Flip the speaker so you have access to the bottom of the device.
    • Use a spudger to remove both rubber pads that protect the bottom of the device.
    Pergunte ao FixBot
    Comentar
  6. Anker Soundcore Select Pro A 3126 Button Panel Replacement: passo 6, imagem 1 %32
    • Using a spudger remove the rubber pad on the top handle to expose 3 screws underneath.
    • Using a Phillips #1 screwdriver, remove the three 6.75 mm screws.
    Pergunte ao FixBot
    Comentar
  7. Anker Soundcore Select Pro A 3126 Button Panel Replacement: passo 7, imagem 1 %32 Anker Soundcore Select Pro A 3126 Button Panel Replacement: passo 7, imagem 2 %32 Anker Soundcore Select Pro A 3126 Button Panel Replacement: passo 7, imagem 3 %32
    • Using a spudger, pry open the front half of the speaker.
    • The front and back halves of the speaker are connected by several cables. Open the speaker slowly and avoid pulling on the cables, as they can be damaged easily.
    Pergunte ao FixBot
    Comentar
  8. Anker Soundcore Select Pro A 3126 Button Panel Replacement: passo 8, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the eight 6.5 mm screws securing the button board.
    Pergunte ao FixBot
    Comentar
  9. Anker Soundcore Select Pro A 3126 Button Panel Replacement: passo 9, imagem 1 %32 Anker Soundcore Select Pro A 3126 Button Panel Replacement: passo 9, imagem 2 %32
    • Use the tip of the spudger to push the black plastic locking tab away from the socket.
    • Pull the ribbon cable straight out of the socket.
    • Remove the old button board.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 31
Últimos 30 dias: 31
Ao todo: 54
