Ir para o conteúdo principal
Anker Soundcore Motion Boom Plus Subwoofer Replacement
O que você precisa
  1. Anker Soundcore Motion Boom Plus Subwoofer Replacement, Case: passo 1, imagem 1 %32 Anker Soundcore Motion Boom Plus Subwoofer Replacement, Case: passo 1, imagem 2 %32 Anker Soundcore Motion Boom Plus Subwoofer Replacement, Case: passo 1, imagem 3 %32
    • Insert an opening tool into the seam between the speaker grille and the chassis.
    • Pry the tool around the top, bottom, and sides until the grille fully releases.
    • Apply gentle pressure to avoid damaging the grille.
    • Remove the grille.
    Pergunte ao FixBot
  2. Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 2, imagem 1 %32 Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 2, imagem 2 %32
    • Remove the two passive radiators on either side of the device.
    • Avoid pulling too hard or with too much force to prevent breaking the passive radiators.
    Pergunte ao FixBot
  3. Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 3, imagem 1 %32 Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 3, imagem 2 %32
    • Remove the sixteen 14 mm Phillips screws, eight on each end of the speaker.
    Pergunte ao FixBot
  4. Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 4, imagem 1 %32 Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 4, imagem 2 %32 Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 4, imagem 3 %32
    • Gently remove the handle from the device by clicking off the handles from the sides and then pulling it off.
    Pergunte ao FixBot
  5. Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 5, imagem 1 %32 Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 5, imagem 2 %32
    • Flip the speaker onto its side and use a spudger to remove the two rubber feet on the bottom of the device.
    Pergunte ao FixBot
  6. Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 6, imagem 1 %32 Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 6, imagem 2 %32
    • Remove the eleven 13 mm Philips screws that secure the driver housing.
    Pergunte ao FixBot
  7. Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 7, imagem 1 %32 Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 7, imagem 2 %32
    • Remove the two 14 mm Phillips screws located on each side of the handle, near the clip points.
    Pergunte ao FixBot
  8. Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 8, imagem 1 %32 Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 8, imagem 2 %32
    • Remove the four 14 mm Philips screws on the top of the device.
    Pergunte ao FixBot
  9. Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 9, imagem 1 %32
    • Insert a spudger into the seam on top of the device.
    • Gently pry the casing open.
    Pergunte ao FixBot
  10. Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 10, imagem 1 %32 Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 10, imagem 2 %32 Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 10, imagem 3 %32
    • Disconnect each of the three cables by gently pulling the connectors out of their sockets.
    • Do not pull with force. The ribbon cables are fragile and easily break.
    Pergunte ao FixBot
  11. Anker Soundcore Motion Boom Plus Subwoofer Replacement, Subwoofer: passo 11, imagem 1 %32 Anker Soundcore Motion Boom Plus Subwoofer Replacement, Subwoofer: passo 11, imagem 2 %32 Anker Soundcore Motion Boom Plus Subwoofer Replacement, Subwoofer: passo 11, imagem 3 %32
    • Remove the four 11 mm Phillips screws securing the right subwoofer.
    • Gently pull the subwoofer out of the device.
    Pergunte ao FixBot
  12. Anker Soundcore Motion Boom Plus Subwoofer Replacement: passo 12, imagem 1 %32
    • Detach the cables connected to the subwoofer.
    • Do not pull with force, as the cables are fragile and easily break.
    • Remove the right subwoofer.
    • Repeat the previous two steps for the left subwoofer.
    Pergunte ao FixBot
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Hayley
Membro desde: 03/26/25
988 Reputação
Autoria de 6 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 31
Ao todo: 259
