Ir para o conteúdo principal
Anker Soundcore Flare Mini Waterproof Outer Shell Replacement
O que você precisa
  1. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Bottom Cover: passo 1, imagem 1 %32 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Bottom Cover: passo 1, imagem 2 %32 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Bottom Cover: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    • The rubber cover of the speaker is glued down.
    • Use precision tweezers to peel the rubber cover off of the bottom of the speaker.
    Pergunte ao FixBot
    Comentar
  2. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: passo 2, imagem 1 %32 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: passo 2, imagem 2 %32 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: passo 2, imagem 3 %32
    • Remove six 10 mm screws holding the plastic cover in place using a Phillips #1 screwdriver.
    • Use your hand to pull the plastic cover off the bottom of the speaker.
    Pergunte ao FixBot
    Comentar
  3. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Motherboard: passo 3, imagem 1 %32 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Motherboard: passo 3, imagem 2 %32 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Motherboard: passo 3, imagem 3 %32
    • Remove the single 10 mm screw holding the motherboard in place using a Phillips #1 screwdriver.
    • Lift the motherboard up.
    • The motherboard is still attached to several wires underneath.
    Pergunte ao FixBot
    Comentar
  4. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: passo 4, imagem 1 %32 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: passo 4, imagem 2 %32 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: passo 4, imagem 3 %32
    • Use precision tweezers to firmly grasp the five power connectors and detach them from the back of the motherboard.
    • When removing the power connectors, do not pull the wires themselves.
    • Remove the motherboard from the speaker.
    Pergunte ao FixBot
    Comentar
  5. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Waterproof Outer Shell: passo 5, imagem 1 %32 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Waterproof Outer Shell: passo 5, imagem 2 %32 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Waterproof Outer Shell: passo 5, imagem 3 %32
    • Remove the four 11 mm screws from the white plastic cover using a Phillips #1 screwdriver.
    • Remove the white plastic cover from the speaker.
    Pergunte ao FixBot
    Comentar
  6. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: passo 6, imagem 1 %32 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: passo 6, imagem 2 %32
    • Remove the other four 11 mm screws holding the outer shell in place with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: passo 7, imagem 1 %32
    • Pull the charging port away from the side of the speaker.
    Pergunte ao FixBot
    Comentar
  8. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: passo 8, imagem 1 %32 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: passo 8, imagem 2 %32 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: passo 8, imagem 3 %32
    • Use a spudger to loosen the cover from the inner components of the speaker.
    • Slide the cover completely off.
    • One wire will still be connected to the shell.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
1Comentário do guia
Where can I purchase the outer shell? Share link please
Arsam Sohail - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 50
Ao todo: 1,062
