Ir para o conteúdo principal
Anker Soundcore Flare Mini Battery Replacement
O que você precisa
  1. Anker Soundcore Flare Mini Battery Replacement, Bottom Cover: passo 1, imagem 1 %32 Anker Soundcore Flare Mini Battery Replacement, Bottom Cover: passo 1, imagem 2 %32 Anker Soundcore Flare Mini Battery Replacement, Bottom Cover: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    • The rubber cover of the speaker is glued down.
    • Use precision tweezers to peel the rubber cover off of the bottom of the speaker.
    Pergunte ao FixBot
    Comentar
  2. Anker Soundcore Flare Mini Battery Replacement: passo 2, imagem 1 %32 Anker Soundcore Flare Mini Battery Replacement: passo 2, imagem 2 %32 Anker Soundcore Flare Mini Battery Replacement: passo 2, imagem 3 %32
    • Remove six 10 mm screws holding the plastic cover in place using a Phillips #1 screwdriver.
    • Use your hand to pull the plastic cover off the bottom of the speaker.
    Pergunte ao FixBot
    Comentar
  3. Anker Soundcore Flare Mini Battery Replacement, Motherboard: passo 3, imagem 1 %32 Anker Soundcore Flare Mini Battery Replacement, Motherboard: passo 3, imagem 2 %32 Anker Soundcore Flare Mini Battery Replacement, Motherboard: passo 3, imagem 3 %32
    • Remove the single 10 mm screw holding the motherboard in place using a Phillips #1 screwdriver.
    • Lift the motherboard up.
    • The motherboard is still attached to several wires underneath.
    Pergunte ao FixBot
    Comentar
  4. Anker Soundcore Flare Mini Battery Replacement: passo 4, imagem 1 %32 Anker Soundcore Flare Mini Battery Replacement: passo 4, imagem 2 %32 Anker Soundcore Flare Mini Battery Replacement: passo 4, imagem 3 %32
    • Use precision tweezers to firmly grasp the five power connectors and detach them from the back of the motherboard.
    • When removing the power connectors, do not pull the wires themselves.
    • Remove the motherboard from the speaker.
    Pergunte ao FixBot
    Comentar
  5. Anker Soundcore Flare Mini Battery Replacement, Waterproof Outer Shell: passo 5, imagem 1 %32 Anker Soundcore Flare Mini Battery Replacement, Waterproof Outer Shell: passo 5, imagem 2 %32 Anker Soundcore Flare Mini Battery Replacement, Waterproof Outer Shell: passo 5, imagem 3 %32
    • Remove the four 11 mm screws from the white plastic cover using a Phillips #1 screwdriver.
    • Remove the white plastic cover from the speaker.
    Pergunte ao FixBot
    Comentar
  6. Anker Soundcore Flare Mini Battery Replacement: passo 6, imagem 1 %32 Anker Soundcore Flare Mini Battery Replacement: passo 6, imagem 2 %32
    • Remove the other four 11 mm screws holding the outer shell in place with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Anker Soundcore Flare Mini Battery Replacement: passo 7, imagem 1 %32
    • Pull the charging port away from the side of the speaker.
    Pergunte ao FixBot
    Comentar
  8. Anker Soundcore Flare Mini Battery Replacement: passo 8, imagem 1 %32 Anker Soundcore Flare Mini Battery Replacement: passo 8, imagem 2 %32 Anker Soundcore Flare Mini Battery Replacement: passo 8, imagem 3 %32
    • Use a spudger to loosen the cover from the inner components of the speaker.
    • Slide the cover completely off.
    • One wire will still be connected to the shell.
    Pergunte ao FixBot
    Comentar
  9. Anker Soundcore Flare Mini Battery Replacement, Battery: passo 9, imagem 1 %32 Anker Soundcore Flare Mini Battery Replacement, Battery: passo 9, imagem 2 %32 Anker Soundcore Flare Mini Battery Replacement, Battery: passo 9, imagem 3 %32
    • Use a spudger to pry the battery out.
    • It will be tough to start, but once you work the top part of the battery out with the spudger, you can pull it the rest of the way by hand.
    Pergunte ao FixBot
    Comentar
Conclusão
3Comentários do guia
where can I buy the battery replacement component ?
Andre Walters - Responder Compartilhar
Amazon, search for “rechargeable lithium ion battery 18650” it has to be a 2600 mAh 3.7v. I didn’t find one with the same connector so I just soldered the old one to the new battery, it works fine.
Mario Ojeda - Responder Compartilhar
Would be nice to have guidance on how to get the shell cable back through the channel. Also, have people had any issues replacing the battery without the foam padding securing it in it's slot?
Lapin Lunarie - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 83
Ao todo: 3,296
