Ir para o conteúdo principal
Anker Soundcore Flare Mini Audio Drivers Replacement
O que você precisa
  1. Anker Soundcore Flare Mini Audio Drivers Replacement, Bottom Cover: passo 1, imagem 1 %32 Anker Soundcore Flare Mini Audio Drivers Replacement, Bottom Cover: passo 1, imagem 2 %32 Anker Soundcore Flare Mini Audio Drivers Replacement, Bottom Cover: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    • The rubber cover of the speaker is glued down.
    • Use precision tweezers to peel the rubber cover off of the bottom of the speaker.
    Pergunte ao FixBot
    Comentar
  2. Anker Soundcore Flare Mini Audio Drivers Replacement: passo 2, imagem 1 %32 Anker Soundcore Flare Mini Audio Drivers Replacement: passo 2, imagem 2 %32 Anker Soundcore Flare Mini Audio Drivers Replacement: passo 2, imagem 3 %32
    • Remove six 10 mm screws holding the plastic cover in place using a Phillips #1 screwdriver.
    • Use your hand to pull the plastic cover off the bottom of the speaker.
    Pergunte ao FixBot
    Comentar
  3. Anker Soundcore Flare Mini Audio Drivers Replacement, Motherboard: passo 3, imagem 1 %32 Anker Soundcore Flare Mini Audio Drivers Replacement, Motherboard: passo 3, imagem 2 %32 Anker Soundcore Flare Mini Audio Drivers Replacement, Motherboard: passo 3, imagem 3 %32
    • Remove the single 10 mm screw holding the motherboard in place using a Phillips #1 screwdriver.
    • Lift the motherboard up.
    • The motherboard is still attached to several wires underneath.
    Pergunte ao FixBot
    Comentar
  4. Anker Soundcore Flare Mini Audio Drivers Replacement: passo 4, imagem 1 %32 Anker Soundcore Flare Mini Audio Drivers Replacement: passo 4, imagem 2 %32 Anker Soundcore Flare Mini Audio Drivers Replacement: passo 4, imagem 3 %32
    • Use precision tweezers to firmly grasp the five power connectors and detach them from the back of the motherboard.
    • When removing the power connectors, do not pull the wires themselves.
    • Remove the motherboard from the speaker.
    Pergunte ao FixBot
    Comentar
  5. Anker Soundcore Flare Mini Audio Drivers Replacement, Waterproof Outer Shell: passo 5, imagem 1 %32 Anker Soundcore Flare Mini Audio Drivers Replacement, Waterproof Outer Shell: passo 5, imagem 2 %32 Anker Soundcore Flare Mini Audio Drivers Replacement, Waterproof Outer Shell: passo 5, imagem 3 %32
    • Remove the four 11 mm screws from the white plastic cover using a Phillips #1 screwdriver.
    • Remove the white plastic cover from the speaker.
    Pergunte ao FixBot
    Comentar
  6. Anker Soundcore Flare Mini Audio Drivers Replacement: passo 6, imagem 1 %32 Anker Soundcore Flare Mini Audio Drivers Replacement: passo 6, imagem 2 %32
    • Remove the other four 11 mm screws holding the outer shell in place with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Anker Soundcore Flare Mini Audio Drivers Replacement: passo 7, imagem 1 %32
    • Pull the charging port away from the side of the speaker.
    Pergunte ao FixBot
    Comentar
  8. Anker Soundcore Flare Mini Audio Drivers Replacement: passo 8, imagem 1 %32 Anker Soundcore Flare Mini Audio Drivers Replacement: passo 8, imagem 2 %32 Anker Soundcore Flare Mini Audio Drivers Replacement: passo 8, imagem 3 %32
    • Use a spudger to loosen the cover from the inner components of the speaker.
    • Slide the cover completely off.
    • One wire will still be connected to the shell.
    Pergunte ao FixBot
    Comentar
  9. Anker Soundcore Flare Mini Audio Drivers Replacement, Audio Drivers: passo 9, imagem 1 %32 Anker Soundcore Flare Mini Audio Drivers Replacement, Audio Drivers: passo 9, imagem 2 %32 Anker Soundcore Flare Mini Audio Drivers Replacement, Audio Drivers: passo 9, imagem 3 %32
    • There are two drivers—one on each side of the speaker.
    • Use a Phillips #1 screwdriver to remove the four 11 mm screws from one driver.
    • Use your hand to pull the driver out of the device.
    • Repeat this step with the other driver.
    Pergunte ao FixBot
    Comentar
  10. Anker Soundcore Flare Mini Audio Drivers Replacement: passo 10, imagem 1 %32 Anker Soundcore Flare Mini Audio Drivers Replacement: passo 10, imagem 2 %32 Anker Soundcore Flare Mini Audio Drivers Replacement: passo 10, imagem 3 %32
    • Use precision tweezers to detach the two wire connectors from the driver.
    • Both drivers are connected to the same wire so removing one side will separate the other driver from the device as well.
    • Remove both drivers from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
1Comentário do guia
what size are the speakers?
Chris - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 48
Ao todo: 1,505
