Ir para o conteúdo principal
Anker SoundCore 2 Speaker Replacement
O que você precisa
  1. Anker SoundCore 2 Speaker Replacement, Front Panel: passo 1, imagem 1 %32 Anker SoundCore 2 Speaker Replacement, Front Panel: passo 1, imagem 2 %32
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Speaker Replacement, Speaker: passo 2, imagem 1 %32 Anker SoundCore 2 Speaker Replacement, Speaker: passo 2, imagem 2 %32 Anker SoundCore 2 Speaker Replacement, Speaker: passo 2, imagem 3 %32
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Speaker Replacement: passo 3, imagem 1 %32 Anker SoundCore 2 Speaker Replacement: passo 3, imagem 2 %32 Anker SoundCore 2 Speaker Replacement: passo 3, imagem 3 %32
    • The speakers do not use wires so when replacing the speaker, make sure you align the metal prongs with the metal clips on the motherboard.
Conclusão
3 outras pessoas executaram este guia.
12Comentários do guia
Excellent guide, my speaker falls to the ground, and one of two speaker stops working, disassemble and verifying, was the speaker clip was loose
Renato Galindo - Responder
Where can I buy a speaker for the repair ? Or will any sized speaker work ?
philcuchetti - Responder
hi, did you manage to buy a replacement speaker? If yes from where pls?
jafarez -
Do someone get a new speaker? I need to buy one!
everton.euclides - Responder
jafarez -
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 22
Últimos 30 dias: 89
Ao todo: 6,318
