Ir para o conteúdo principal
Anker SoundCore 2 Microphone Replacement
O que você precisa
  1. Anker SoundCore 2 Microphone Replacement, Front Panel: passo 1, imagem 1 %32 Anker SoundCore 2 Microphone Replacement, Front Panel: passo 1, imagem 2 %32
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Microphone Replacement, Microphone: passo 2, imagem 1 %32 Anker SoundCore 2 Microphone Replacement, Microphone: passo 2, imagem 2 %32 Anker SoundCore 2 Microphone Replacement, Microphone: passo 2, imagem 3 %32
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Flip up the speaker mount panel from the speaker housing case.
  3. Anker SoundCore 2 Microphone Replacement: passo 3, imagem 1 %32 Anker SoundCore 2 Microphone Replacement: passo 3, imagem 2 %32 Anker SoundCore 2 Microphone Replacement: passo 3, imagem 3 %32
    • Disconnect the microphone wire from the motherboard.
    • Use a spudger to pry the microphone out of the speaker mount panel.
    • The microphone is held in place with glue, so you may need to re-glue the new microphone onto the speaker mount panel.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 28
Ao todo: 1,290
