Ir para o conteúdo principal
Anker SoundCore 2 Battery Replacement
O que você precisa
  1. Anker SoundCore 2 Battery Replacement, Front Panel: passo 1, imagem 1 %32 Anker SoundCore 2 Battery Replacement, Front Panel: passo 1, imagem 2 %32
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Battery Replacement, Battery: passo 2, imagem 1 %32 Anker SoundCore 2 Battery Replacement, Battery: passo 2, imagem 2 %32 Anker SoundCore 2 Battery Replacement, Battery: passo 2, imagem 3 %32
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Battery Replacement: passo 3, imagem 1 %32 Anker SoundCore 2 Battery Replacement: passo 3, imagem 2 %32 Anker SoundCore 2 Battery Replacement: passo 3, imagem 3 %32
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard to expose the battery.
  4. Anker SoundCore 2 Battery Replacement: passo 4, imagem 1 %32 Anker SoundCore 2 Battery Replacement: passo 4, imagem 2 %32
    • Use a nylon spudger to remove the battery from the speaker casing.
    • Caution: Do not use metal prying tools on a battery—these can puncture an unprotected battery, potentially causing a fire.
    • The battery is glued down so it may be difficult to remove.
  5. Anker SoundCore 2 Battery Replacement: passo 5, imagem 1 %32 Anker SoundCore 2 Battery Replacement: passo 5, imagem 2 %32
    • Unplug the wire that connects the battery with the motherboard.
    • When replacing the battery, plug in the new battery where the old one was plugged in.
Conclusão
Uma outra pessoa concluiu este guia.
3 comentários
It would be nice to have the specifications of the battery so availability can be checked before disassembly.
Michael Anderson - Responder
7.2V, 2550 mAh, 18.36 Watt - Hour
Kang Le - Responder
Hey I had a question.So i kind of dipped anker sound core 2 in water eithout the charging cover on and now it wont turn on.Can you Help what might be the problem here?
abdurreheembakir - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 17
Últimos 7 dias: 117
Últimos 30 dias: 501
Duração total: 5,738
