Ir para o conteúdo principal
Anker 2.4G Wireless Mouse DPI button Replacement
O que você precisa
    1. Anker 2.4G Wireless Mouse DPI button Replacement, DPI button: passo 1, imagem 1 %32
      • Use screwdriver to pry off the stickers marked in red to reveal the location of the 4 screws.
      Pergunte ao FixBot
      Comentar
    2. Anker 2.4G Wireless Mouse DPI button Replacement: passo 2, imagem 1 %32
      • Remove the 4 screws to continue.
      Pergunte ao FixBot
      Comentar
    3. Anker 2.4G Wireless Mouse DPI button Replacement: passo 3, imagem 1 %32 Anker 2.4G Wireless Mouse DPI button Replacement: passo 3, imagem 2 %32
      • Pry the center of the mouse apart to separate the upper and lower housing of the boards.
      Pergunte ao FixBot
      Comentar
    4. Anker 2.4G Wireless Mouse DPI button Replacement: passo 4, imagem 1 %32
      • Remove the wires from the white crimp headers. this will separate the upper and lower housing units of the mouse.
      • Pull as far up on the wire as possible, being as careful as possible to avoid ripping the wires.
      Pergunte ao FixBot
      Comentar
    5. Anker 2.4G Wireless Mouse DPI button Replacement: passo 5, imagem 1 %32 Anker 2.4G Wireless Mouse DPI button Replacement: passo 5, imagem 2 %32
      • Take the upper housing of the mouse and begin to remove the two screws (highlighted in red) that hold the board in place.
      Pergunte ao FixBot
      Comentar
    6. Anker 2.4G Wireless Mouse DPI button Replacement: passo 6, imagem 1 %32
      • Gently remove board.
      Pergunte ao FixBot
      Comentar
    7. Anker 2.4G Wireless Mouse DPI button Replacement: passo 7, imagem 1 %32 Anker 2.4G Wireless Mouse DPI button Replacement: passo 7, imagem 2 %32
      • The DPI button is the red push button highlighted in red.
      • To remove it, flip the board over and desolder the wires highlighted in orange.
      • Replace component with new component and resolder back in place.
      Pergunte ao FixBot
      Comentar
Conclusão
Colin
Membro desde: 02/10/14
409 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 1-39, Maness Winter 2014 Membro de Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Membros
Autoria de 48 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 42
Ao todo: 3,921
