Ir para o conteúdo principal
AmazonBasics BTV1 Speaker Replacement
O que você precisa
  1. AmazonBasics BTV1 Speaker Replacement, Speaker: passo 1, imagem 1 %32 AmazonBasics BTV1 Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
    • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
    Pergunte ao FixBot
    Comentar
  2. AmazonBasics BTV1 Speaker Replacement: passo 2, imagem 1 %32 AmazonBasics BTV1 Speaker Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
    • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
    Pergunte ao FixBot
    Comentar
  3. AmazonBasics BTV1 Speaker Replacement: passo 3, imagem 1 %32 AmazonBasics BTV1 Speaker Replacement: passo 3, imagem 2 %32
    • Tilt the case downwards until the speakers fall out of their housings.
    • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
    Pergunte ao FixBot
    Comentar
  4. AmazonBasics BTV1 Speaker Replacement: passo 4, imagem 1 %32 AmazonBasics BTV1 Speaker Replacement: passo 4, imagem 2 %32
    • Gently pull the two plastic connectors from the motherboard.
    • Lift the front panel of the case and remove the speakers.
    Pergunte ao FixBot
    Comentar
Conclusão
Chris Shannon
Membro desde: 02/01/16
1.039 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 14-2, Lacy Spring 2016 Membro de USF Tampa, Team 14-2, Lacy Spring 2016
USFT-LACY-S16S14G2
3 Membros
Autoria de 5 guias
1Comentário do guia
Where do you get replacement speakers? What kind?
laurieshorter - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 18
Ao todo: 2,348
