Ir para o conteúdo principal
AmazonBasics BTV1 Battery Replacement
O que você precisa
  1. AmazonBasics BTV1 Battery Replacement, Battery: passo 1, imagem 1 %32 AmazonBasics BTV1 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
    • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
    Pergunte ao FixBot
    Comentar
  2. AmazonBasics BTV1 Battery Replacement: passo 2, imagem 1 %32 AmazonBasics BTV1 Battery Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
    • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
    Pergunte ao FixBot
    Comentar
  3. AmazonBasics BTV1 Battery Replacement: passo 3, imagem 1 %32 AmazonBasics BTV1 Battery Replacement: passo 3, imagem 2 %32
    • Tilt the case downwards until the speakers fall out of their housings.
    • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
    Pergunte ao FixBot
    Comentar
  4. AmazonBasics BTV1 Battery Replacement: passo 4, imagem 1 %32 AmazonBasics BTV1 Battery Replacement: passo 4, imagem 2 %32
    • Gently pull each plastic connector from the motherboard.
    • Take a note of which connector goes with each component for easy reassembly.
    • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
    Pergunte ao FixBot
    Comentar
  5. AmazonBasics BTV1 Battery Replacement: passo 5, imagem 1 %32 AmazonBasics BTV1 Battery Replacement: passo 5, imagem 2 %32
    • Lift the motherboard off the face plate, exposing the battery.
    • Lift the battery out of its housing.
    • Use caution when using tools around the battery; batteries can be dangerous if punctured.
    Pergunte ao FixBot
    Comentar
Conclusão
10 outras pessoas executaram este guia.
Chris Shannon
Membro desde: 02/01/16
1.039 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 14-2, Lacy Spring 2016 Membro de USF Tampa, Team 14-2, Lacy Spring 2016
USFT-LACY-S16S14G2
3 Membros
Autoria de 5 guias
8Comentários do guia
donde consigo la bateria?
bnet_d72 - Responder Compartilhar
Nice job, Chris! Thank you.
David Printz - Responder Compartilhar
Hello, anybody know where to get the battery from?
Thank you in advance!
Carlos - Responder Compartilhar
Need information on where to get a replacement battery!
dan - Responder Compartilhar
Whar kind of battery is it? I need to know so that I can order a new one.
Makayla Kersting - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 47
Ao todo: 3,759
