Ir para o conteúdo principal
AmazonBasics B00Q3KFX8U Power Switch Replacement
O que você precisa
  1. AmazonBasics B00Q3KFX8U Power Switch Replacement, Drive Gear: passo 1, imagem 1 %32
    • Remove the shredder assembly from the paper scrap bin.
    Pergunte ao FixBot
    Comentar
  2. AmazonBasics B00Q3KFX8U Power Switch Replacement: passo 2, imagem 1 %32
    • Remove the two 10mm PH1 screws holding the small black panel in place.
    Pergunte ao FixBot
    Comentar
  3. AmazonBasics B00Q3KFX8U Power Switch Replacement: passo 3, imagem 1 %32 AmazonBasics B00Q3KFX8U Power Switch Replacement: passo 3, imagem 2 %32
    • Remove the six 14mm PH1 screws holding the bottom cover in place.
    • Remove the cover by lifting straight upwards.
    • One of the screws will be hidden beneath a warranty sticker. Simply push the head of the screwdriver through the sticker to access the screw.
    Pergunte ao FixBot
    Comentar
  4. AmazonBasics B00Q3KFX8U Power Switch Replacement: passo 4, imagem 1 %32
    • Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
    • The blades are sharp. Coming into contact with them may result in injury.
    Pergunte ao FixBot
    Comentar
  5. AmazonBasics B00Q3KFX8U Power Switch Replacement: passo 5, imagem 1 %32 AmazonBasics B00Q3KFX8U Power Switch Replacement: passo 5, imagem 2 %32
    • Remove the five 8mm PH2 screws from the bracket holding the gears in place.
    Pergunte ao FixBot
    Comentar
  6. AmazonBasics B00Q3KFX8U Power Switch Replacement: passo 6, imagem 1 %32
    • Use a metal spudger to pry the bracket from the main shredder assembly.
    • If the bracket is attached too tightly for the spudger, carefully use a metal screwdriver to pry it loose.
    Pergunte ao FixBot
    Comentar
  7. AmazonBasics B00Q3KFX8U Power Switch Replacement: passo 7, imagem 1 %32 AmazonBasics B00Q3KFX8U Power Switch Replacement: passo 7, imagem 2 %32
    • Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
    Pergunte ao FixBot
    Comentar
  8. AmazonBasics B00Q3KFX8U Power Switch Replacement, Motor: passo 8, imagem 1 %32
    • Remove the four 18mm PH2 screws holding the motor to the main shredder assembly.
    Pergunte ao FixBot
    Comentar
  9. AmazonBasics B00Q3KFX8U Power Switch Replacement: passo 9, imagem 1 %32
    • Disconnect the motor from the motherboard by either clipping the wires, or using a soldering iron to disconnect the wires directly at the board.
    • To reattach the motor, solder the wires back together, or to the motherboard depending on how you removed them.
    Pergunte ao FixBot
    Comentar
  10. AmazonBasics B00Q3KFX8U Power Switch Replacement, Power Cable: passo 10, imagem 1 %32
    • Remove the two 8mm PH1 screws holding the IR sensor wire in place. This will give you more room to work with later on.
    Pergunte ao FixBot
    Comentar
  11. AmazonBasics B00Q3KFX8U Power Switch Replacement: passo 11, imagem 1 %32 AmazonBasics B00Q3KFX8U Power Switch Replacement: passo 11, imagem 2 %32
    • Remove the two 10mm PH1 screws holding the motherboard in place.
    • Remove the motherboard by lifting straight upwards from the top cover.
    Pergunte ao FixBot
    Comentar
  12. AmazonBasics B00Q3KFX8U Power Switch Replacement: passo 12, imagem 1 %32
    • To disconnect the power wire, remove the black and white wires on the far edges of the motherboard.
    • To reassemble, solder the wires back to the motherboard in the same location as they previously were.
    • When reassembling, be sure to replace the wires in the correct locations. Reversing the wires will short circuit the motherboard and may damage the device or injure yourself.
    Pergunte ao FixBot
    Comentar
  13. AmazonBasics B00Q3KFX8U Power Switch Replacement, Power Switch: passo 13, imagem 1 %32 AmazonBasics B00Q3KFX8U Power Switch Replacement, Power Switch: passo 13, imagem 2 %32
    • Remove the switch by unsoldering the 8 solder points on the motherboard.
    • To reinstall, solder the switch back into the same location on the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
William Foley
Membro desde: 03/25/16
548 Reputação
Autoria de 4 guias
Equipe
2Comentários do guia
Where can I get parts for AmazonBasics shredders?
burkphoto - Responder Compartilhar
I am looking for the replacement switch (the one that toggle On/Off/Reverse/Auto). Does anyone know where I can find one?
Eve L - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 37
Ao todo: 1,976
