Ir para o conteúdo principal
AmazonBasics B00Q3KFX8U Drive Gear Replacement
O que você precisa
    1. AmazonBasics B00Q3KFX8U Drive Gear Replacement, Drive Gear: passo 1, imagem 1 %32
      • Remove the shredder assembly from the paper scrap bin.
      Pergunte ao FixBot
      Comentar
    2. AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 2, imagem 1 %32
      • Remove the two 10mm PH1 screws holding the small black panel in place.
      Pergunte ao FixBot
      Comentar
    3. AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 3, imagem 1 %32 AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 3, imagem 2 %32
      • Remove the six 14mm PH1 screws holding the bottom cover in place.
      • Remove the cover by lifting straight upwards.
      • One of the screws will be hidden beneath a warranty sticker. Simply push the head of the screwdriver through the sticker to access the screw.
      Pergunte ao FixBot
      Comentar
    4. AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 4, imagem 1 %32
      • Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
      • The blades are sharp. Coming into contact with them may result in injury.
      Pergunte ao FixBot
      Comentar
    5. AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 5, imagem 1 %32 AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 5, imagem 2 %32
      • Remove the five 8mm PH2 screws from the bracket holding the gears in place.
      Pergunte ao FixBot
      Comentar
    6. AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 6, imagem 1 %32
      • Use a metal spudger to pry the bracket from the main shredder assembly.
      • If the bracket is attached too tightly for the spudger, carefully use a metal screwdriver to pry it loose.
      Pergunte ao FixBot
      Comentar
    7. AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 7, imagem 1 %32 AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 7, imagem 2 %32
      • Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
      Pergunte ao FixBot
      Comentar
Conclusão
William Foley
Membro desde: 03/25/16
548 Reputação
Autoria de 4 guias
Equipe
5Comentários do guia
Where does one buy these gear parts?
opticdreams - Responder Compartilhar
Hi, you can buy the gear here: https://www.ebay.com/itm/116169745117
Mr. Master - Responder Compartilhar
I need big wheel for Bonsaii C220-A and need a duel gear wheel (1.6 inches and 0.5 inches) Apelila Apelila paper shredder
Raju Nivarthi - Responder Compartilhar
Send me a message on eBay, https://www.ebay.com/usr/krunkz, I will recreate your damaged gears for free if you can mail them to me.
Shredder Gears - Responder Compartilhar
I would not buy the gears from that link on ebay. I paid 10 dollars for 2 3D printed gears. Both stripped almost immediately. I applied new grease and do not think it was my error, but rather poor quality gear replacements. Not worth the time or money.
acoest - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 52
Ao todo: 2,299
