Ir para o conteúdo principal
Amazon Kindle 8 Power Button Replacement
O que você precisa
  1. Amazon Kindle 8 Power Button Replacement, Front Cover: passo 1, imagem 1 %32 Amazon Kindle 8 Power Button Replacement, Front Cover: passo 1, imagem 2 %32
    • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
    • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
    • Keep even pressure to avoid any cracks.
    • Lift front cover once all clips are disengaged.
    • Lift the screen gently so that it is not cracked.
  2. Amazon Kindle 8 Power Button Replacement: passo 2, imagem 1 %32 Amazon Kindle 8 Power Button Replacement: passo 2, imagem 2 %32
    • Insert the spudger between the inner cover and the screen.
    • Gently work your way around to loosen the front cover.
    • Carefully lift the front cover from the device.
  3. Amazon Kindle 8 Power Button Replacement, Motherboard: passo 3, imagem 1 %32 Amazon Kindle 8 Power Button Replacement, Motherboard: passo 3, imagem 2 %32
    • Use a T4 Torx screwdriver to remove the seven 3 mm screws around the perimeter of the device.
  4. Amazon Kindle 8 Power Button Replacement: passo 4, imagem 1 %32 Amazon Kindle 8 Power Button Replacement: passo 4, imagem 2 %32
    • Lift the screen and motherboard from the back cover.
  5. Amazon Kindle 8 Power Button Replacement, Power Button: passo 5, imagem 1 %32 Amazon Kindle 8 Power Button Replacement, Power Button: passo 5, imagem 2 %32
    • On the back cover, from the outside of the kindle, use your finger to push the power button through its hole.
    • Remove the power button.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Luke
Membro desde: 09/25/24
420 Reputação
Autoria de 5 guias
1Comentário do guia
partial fix, that does not show how to remove and replace the button in the subject. Please integrate step-by-step guide.
SimoneGallina - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 52
Ao todo: 503
